Glossy Paints
    February 2007
Glossy Paints
Posted by mitsdude on Tuesday, November 6, 2012 9:08 AM
I've noticed that when I spray paint (rattle can) gloss enamels they can sometimes taken as long as a week to dry. They just stay "tacky" for days.  Especially reds and yellow. Any ideas on why and how to speed it up?
Posted by Don Stauffer on Tuesday, November 6, 2012 9:17 AM
I built a drying booth to speed things up. It is a simple box with a 60 watt light bulb in it, with some openings in the top. I put one of those plastic trays on top,- the kind we take our models to shows in-  mounted upside down, as a parts chamber.
Others use food dissicators, but some of those run pretty hot and have warped parts. I put a dimmer in series with the bulb so I could adjust temp.  Turns out that was not needed- wide open the sixty watts runs the chamber at about 105 degrees.
Thinner coats help.  Try several thin coats, sanding between coats.  But controlling gloss and thinness of a rattle can coat is hard.  Last coat still needs to be a bit heavy to get good gloss.
