getting back to airbrushing questions
    March 2009
Posted by wolfhammer1 on Friday, November 30, 2012 11:11 PM
I fired up my Badger 150 airbrush for the first time in about 20 years last night , on a new set-up with a tanked air compressor and ran into something I had never seen or heard of before.  I was getting bubbles in the paint cup, and the brush did not seem to want to spray unless I had it pretty much wide open.  I have a new regulator, and it was reading between 20-30 psi to get any paint out.  I was using Model master acrylics, and thinned the paint out of ther bottle, but the brush did not even like shooting thinner when i was cleaning up.  what's going on, please
    February 2015
Posted by Bick on Saturday, December 1, 2012 7:36 AM
Sounds to me that your nozzle cap is not firmly screwed on or the little teflon washer (back of nozzle where it screws into the AB) is faulty or missing.
    March 2009
Posted by wolfhammer1 on Saturday, December 1, 2012 11:09 AM
I will check the washer, after 20 years dry, it may have gotten dry and is not sealing well.  Thanks
    January 2012
Posted by Misty on Saturday, December 1, 2012 11:10 AM
the cure for most problems is strip it down, clean it out, make sure its all screwed back together properly and check the needle tip is not bent/ damaged.
I had the same problem and it was a bent needle tip, just dragged it backwards ONLY on some micro mesh pads to get a straight fine tip again.
If this doesn't help check the little nozzle is not split. this can happen if you ram the needle in to hard.
    March 2009
Posted by wolfhammer1 on Saturday, December 1, 2012 11:11 AM
thanks, I will check the nozzle as well.
Posted by Don Stauffer on Saturday, December 1, 2012 12:54 PM
Bick
Bick's answers look right to me.  Any time that has happened to me it is one of those two, usually the teflon washer. I keep several in stock and consider them as perishable supplies.
    March 2009
Posted by wolfhammer1 on Saturday, December 1, 2012 11:36 PM
Thanks Don
    March 2009
Posted by wolfhammer1 on Sunday, January 13, 2013 9:45 PM
All, replaced the washer, gun works much better, need to work on thinning paint enough.  Thanks for the help
