Tape line
    October 2004
Tape line
Posted by AndrewT on Tuesday, January 29, 2013 9:53 AM
Good afternoon
I have masked my model with tamiya masking tape. I then sprayed enamel paint. When I removed the tape, a tape line is created.How can I polish this to have one evenly nice surface?
Regards Andrew
Dre
    June 2007
Posted by Dre on Tuesday, January 29, 2013 10:58 AM
You could try using superfine grit polishing cloths or papers to smooth that out with very light pressure.
When masking like that, I try to spray away from the tape, not into it, to help avoid that issue but sometimes it is inevitable.
    March 2010
Posted by ACESES5 on Tuesday, January 29, 2013 2:36 PM
When you spray over your mask do it in 2 or 3 light coats and spray straight down or from behind your mask never spray aganist the edge that you want left. Then when you pull your mask pull the tape back over itself at a low sharp angle. If there is a ridge there it will come off with the tape.    ACESES5
    October 2004
Posted by AndrewT on Wednesday, January 30, 2013 6:08 AM
Thanks for the useful tips
Posted by Don Stauffer on Wednesday, January 30, 2013 9:28 AM
Depends on whether paint is gloss or flat.  With gloss paint superfine sand paper or polishing cloth alone will do job.  However, that screws up flat finish, so flats need a dull coat after polishing. In fact, if the ridge isn't TOO thick, sometimes clear coats themselves reduce the visibililty of the line.
    March 2012
Posted by mustang1989 on Thursday, January 31, 2013 11:28 PM
Another approach for future use is the use of Silly Putty which you can get at Walmart. This stuff works great for masking. You can create hard demarcation lines or soft ones depending on how you lay the putty down. When done just pull it up at a sharp angle away from the "fresh painted surface" . Just go with Dre and ACES advice on the direction of the paint sprayed from the airbrush.
 Forum | Modelers Social Club Forum (proboards.com)
