Enamel Lacquer Acrylic compatability
    August 2012
Posted by JMorgan on Monday, February 18, 2013 8:22 PM
I was just reading Aaron Skinner's new book and he says not to use lacquer over enamels and acrylics. What is Testor's dullcote and glosscote for if but that very thing? What is correct? I have used dullcote over enamels for years without trouble but hesitate now.
    June 2010
Posted by DoogsATX on Monday, February 18, 2013 9:38 PM
When it comes to paint, there are so many different variables that the definitions of lacquer, acrylic and enamel are almost laughable. I mean, Tamiya's often called an acrylic lacquer. Gunze has something called "solvent-based acrylics". I've had Gunze gloss clear attack other Gunze paints and Tamiya paints, but not MM enamels.
The best (and only) bet if you're unsure it to test the combo out ahead of time. But if it works and has worked for years, keep on keepin' on in my opinion.
On the Bench: 1/32 Trumpeter P-47 | 1/32 Hasegawa Bf 109G | 1/144 Eduard MiG-21MF x2
On Deck:  1/350 HMS Dreadnought
    August 2005
Posted by Phil_H on Monday, February 18, 2013 10:23 PM
The general rule of thumb is that the "hotter" paints should not be applied over "cooler" paints.
In general terms, in order of "heat",
1: lacquer
2: enamel
3: acrylic
That is to say that enamels and acrylics can be applied over lacquers and acrylics over enamels safely.
However, we know that for many years, modellers have applied lacquers in the form of Testors glosscote/dullcote and Tamiya spray clear gloss/flat over enamels and acrylics with no ill effects.
This is often down to technique. Always allow sufficient time for the colour coats to fully cure before applying the clearcoats. When applying the clearcoats, apply the first few coats as a light "mist coat", allowing each successive coat to dry before recoating.  This forms a barrier over the underlying paint which protects it from the harsher solvents in the lacquer.
Many a modeller has ignored this process and applied a wet coat directly to their colour coats and watched in horror as the colour coat wrinkled and shrivelled before their eyes.
As mentioned, in recent years, the line between the different paint bases has become blurred and indistinct. It is now possible to have lacquer, enamel and acrylic paints on your shelf and use a single (lacquer) thinner  for all three (depending on brand of paint). So to reiterate what DOOGSATX  said above, if in doubt, test on scrap first.
    October 2010
Posted by hypertex on Tuesday, February 19, 2013 8:23 AM
I never bought the rule that says you can't apply a lacquer over any other type of paint. There are too many exceptions for this "rule" to be useful. As Doogs mentioned, there are many formulas for paints and the groupings are confusing. Lacquer and enamel paint have never been precise terms--they are not named from their ingredients. There is no universal governing body that sets out precise definitions for these types of paints.   As a result, we get confused.
One myth is that all acrylic paints are water-based. There is no rule or law that says paints labelled acrylic must be water-based. Most acrylic paints are water-based, but that's because many acrylic polymers are water soluble. But acrylic polymers can also be soluble in alcohols, esters, and such. The term "acrylic" refers to the paint's solid film-former (aka binder). In chemistry terms, an acrylic polymer is based on the structure of acrylic acid.  Thus if a paint's solid film-former is an acrylic polymer, then by definition it is an acrylic paint, regardless of which solvent(s) is used.
Tamiya's acrylic paints are not your typical acrylic paints. Tamiya uses alcohols and a glycol ether in addition to water as a solvent. But they as still acrylic paints. While Tamiya's acrylics probably are not lacquers, there is no rule that says a lacquer paint cannot have an acrylic binder (hence the acrylic lacquers in the auto industry).
Paint incompatibility happens when the solvents in one paint dissolve the binder in the paint underneath it. Since paint companies keep the binder ingredients secret, it is not possible to predict which solvents will dissolve which paints. Hence the cardinal advice is to always test on something other than your model, and always allow the paint to fully cure before applying another paint.
Chris
    August 2005
Posted by Phil_H on Tuesday, February 19, 2013 4:34 PM
hypertex
I have been saying this for years, but it's hard to change preconceptions. People try to say Tamiya acrylics aren't "true" acrylics because of this that or something else. They are indeed acrylic based because they use an acrylic polymer binder. They are, however, remarkably flexible in that they are compatible with a wider range of solvents than many other paints.
    March 2010
Posted by Nathan T on Thursday, February 21, 2013 11:20 AM
Very true Phil. I no way does Acrylic mean "water based". But, generally in the modeling world, paints with Acrylic polymers are formulated to be water based. The main thing is if you are using a hotter solvent, like laquer, over something non-laquer, just apply it very carefully misting it on with the airbrush.
