Using chalk pastels and over spraying
    March 2010
Posted by Fla Modeler on Thursday, March 14, 2013 2:43 PM
I recently did a model and used chalk pastels for weathering.  I did really nice job (I thought) only to have all the coloring disappear when I over sprayed with a clear, flat coat.  When the pastels got wet, they just vanished...at least most of it did.
Is there any special way to do this?
Thanks,
Mike in The Villages, Florida
Posted by Bish on Thursday, March 14, 2013 2:57 PM
Everything i have read says they must be added after the flat coat, there's no other way. They are quite resilient as long as its not handled to much.
    November 2004
Posted by Bronto on Thursday, March 14, 2013 3:24 PM
I concur with Bish.  Any clear coating you put over pastels will greatly reduce the effects of them.
mgh
    May 2011
Posted by mgh on Thursday, March 14, 2013 5:15 PM
I have had the same problem, and have never found a solution.  Some have told me that they use a fixer, and apparently some brands of weathering powder make their own special fixer.  I have experimented with mineral spirits as a fixer, and it might have helped.  The mineral spirits allow the powder, or chalk, to flow into recesses, and when it evaporates you get a "dusty" line.
But I have to say that nothing I have tried really works well.  The commercial weathering powders I bought hold up slightly better than when I used chalk, but would still disappear.  I  now do as Bish suggested, and leave the weathering powders without trying to clear coat them.
I had exactly what you described happen to me, had a kit that I thought looked good, put a dull coat over it, and there was not a trace of pigment left!
    February 2011
Posted by gunner_chris on Thursday, March 14, 2013 9:47 PM
I've used this method to weather model rail cars, and had to do it in layers.
As mentioned earlier start with a clear coat (I use dull), then apply the chalk. Seal with dull coat and repeat as required building up the effect.
    March 2010
Posted by Fla Modeler on Saturday, March 16, 2013 3:14 PM
Thanks guys, I was afraid of that.  I'll try the multi-layer dull coat apps and see how that goes.  Either that, or try to get better at weathering with spray or dry-brush.
Posted by Bish on Saturday, March 16, 2013 3:25 PM
Mike, is it armour, aircraft or something else your building.
    April 2006
Posted by waynec on Monday, March 18, 2013 4:29 PM
i agree with bish. i wear a cotton gloves to handle the model after painting and don't spray anything over the powders. been using tamiya but will be trying railroad FR something, pastels and eye shadow.
Никто не Забыт    (No one is Forgotten)
Ничто не Забыто  (Nothing is Forgotten)
