Decanting spray paint
    February 2005
Posted by Brownie on Monday, April 8, 2013 4:44 PM
Does anyone have a sure fire way of sealing the straw to the spray nozzle when decanting spray paint? I have tried masking tape, duct tape  but can never get a tight enough seal to keep paint from spraying everywhere!
 Any suggestions would be greatly appreciated.
    July 2012
Posted by littletimmy on Monday, April 8, 2013 5:01 PM
Depending on the manufacturer of the spray can you may be able to use the spray nozzle and straw from a WD40 can.  I keep a nozzle with the straw glued on and just swap it with whatever can im using.
you could also try putting the can inside a large zipper bag and then spraying into the bottle.
 Dont worry about the thumbprint, paint it Rust , and call it "Battle Damage"
    January 2012
Posted by Misty on Monday, April 8, 2013 5:40 PM
I use jumbo straws that have a larger bore than normal. the type used to drink thick milkshakes etc. They are much easier to seal with normal masking tape
Or blutac and the paint just runs down the straw into the pot instead of spurting all over the place due to the bigger bore snd lower pressure .Much much better.
    August 2007
Posted by DUSTER on Monday, April 8, 2013 7:41 PM
talentless
OH Boy!  a real reason the get another milkshake or malt  yum!
Seriously good tips I've always wondered how to decant "cleanly"
Steve
    February 2011
Posted by Hokey on Tuesday, April 9, 2013 4:32 PM
Brownie
Very good video http://youtu.be/2W3y36H-u_0
    February 2007
Posted by mitsdude on Thursday, April 11, 2013 2:26 AM
My tried and true method requires a plastic cup (as in "Solo"), air brush jar, and a pair of latex gloves.
With one gloved hand I spray into the cup. At the same time I mostly seal the top (opening) of the cup with the other gloved hand to keep the spray in. I then quickly transfer the paint from the cup to the air brush jar. The reason being I once let the paint sit in the plastic cup for about 10 minutes. When I came back there was a spreading puddle of paint on my workbench top. The paint had melted the bottom of the cup!!!
I've tried spraying directly into the air brush jar but its a little to shallow and makes a huge mess.
Also, this should be done outdoors on a warmish day. Hold at arms length and be very aware of wind direction!
You could of course use any type of container in place of the Solo type cup. I'm sure some plastic would work without melting.
Hey, this works for me!!!!!
    February 2005
Posted by Brownie on Thursday, April 11, 2013 10:25 AM
Thanks for the video link!! Very good !
