Help preshade with tamiya nato black toooo dark showing through red enamel overcoats
    April 2013
Posted by Clogger on Monday, April 29, 2013 9:00 PM
I'm painting the revell London bus and have made the mistake applying a NATO black preshade prior to painting Humbrol red enamel gloss.  I've already painted 2 coats of the red enamel and the preshade is way too dark still. I feel I need to strip the paint off and I'm thinking of trying a test with oven cleaner.  Any suggestions as to how to remedy this problem?  I think per shading is probably not required and I wish I just painted the enamel red first.
    May 2011
Posted by AceHawkDriver on Monday, April 29, 2013 11:16 PM
Instead of stripping the paint off, I would try using a lighter gray primer.  The primer should cover the NATO Black thus preventing the problem.  Some detail could be lost if you're not careful and apply a light coat.  Red, yellow, and white are notorious for being hard to paint.
If all else fails, I've read simple green is effective and a little easier to use.
Hope it helps!
Peace through superior firepower.
Brian
    April 2013
Posted by Clogger on Tuesday, April 30, 2013 1:02 AM
Thanks, I'll try a little grey primer on a discreet part.
    April 2013
Posted by Clogger on Tuesday, April 30, 2013 1:26 AM
I presume the grey primer would need to be enamel based as the top coat is enamel.
    March 2010
Posted by Nathan T on Tuesday, April 30, 2013 8:50 AM
Keep going with the red, sometimes depending upon paint and thinner ratios it can take up to 3-8 coats to get the right effect. No rules on how many coats you can have. 2 coats is never enough.
    April 2013
Posted by Clogger on Tuesday, April 30, 2013 4:37 PM
Thanks, I did in fact use v thin red layers.  I applied a slightly thicker layer yesterday and the preshade is disappearing.  My only worry is losing the detail.
    June 2010
Posted by montague on Wednesday, May 1, 2013 12:00 AM
Use acrylics if paint build up is a worry. dries faster to check the coverage too.
    April 2013
Posted by Clogger on Wednesday, May 1, 2013 1:34 AM
The red layers I've laid down are enamels.  I didn't think acrylic paint would sit on the enamel paint?
    June 2010
Posted by montague on Thursday, May 2, 2013 12:25 AM
why not?
    April 2013
Posted by Clogger on Thursday, May 2, 2013 1:02 AM
Don't know? I'll give it a go.
    April 2013
Posted by mrmartin75 on Thursday, May 2, 2013 1:10 AM
you can lay acrylics over enamels, just not enamels over acrylics..unless you put down a layer of future or some sort of clearcoat. even then, i've still heard horror stories.
it's just the acrylic may look flat compared to the enamel. then just gloss up the acrylic.
