What Red For B-17
    June 2013
What Red For B-17
Posted by Mjmueller on Wednesday, June 12, 2013 7:12 AM
Hello,
Could someone shed some light on what Red to use for the Revell B-17 ChowHound.  I would really like the Model Master Enamel, but is this to glossy?  I suppose if I put a dull coat over it, it would not be glossy.
Thank You,
MJ
    June 2013
Posted by Mjmueller on Wednesday, June 12, 2013 2:49 PM
Well, I went with the Flat Red from Tamiya, I hope this looks nice.  Also, I was wondering about the de-icer lines on the leading edge of the wings.  I do not see that these are decals.  Does anyone have any tips for these lines? or just regular masking off.
Thanks
MJ
Posted by Bish on Wednesday, June 12, 2013 3:49 PM
For red on US aircraft I would use Tamiya. I don't know what the FS code would be.
As for the de icer lines, I assume these are the black bit on the leading edge of the wings. I normally brush paint mine, but given the straight line on the 17, masking and spray would be possible.
    July 2004
Posted by stikpusher on Wednesday, June 12, 2013 5:57 PM
The most likely shade of red would be Insignia Red, if talking about the red on the tail surfaces.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    June 2013
Posted by Mjmueller on Wednesday, June 12, 2013 6:21 PM
Hello,
Thanks for the reply's.  I did learn that the de-icer lines are easy to brush paint because they are raised.  but the red I learned you can't paint Tamiya worth crap.  so I have opted to use the Testors Enamel Red.
Thank You,
MJ
Posted by Bish on Wednesday, June 12, 2013 11:55 PM
I take it your using a brush rather than an airbrush. Tamiya is very tricky to brush on. You can't go over that stuff while its still wet. Its a real pain.
Posted by Don Stauffer on Thursday, June 13, 2013 9:14 AM
Testors does make a flat red.  And, yes, if you dullcoat a gloss enamel, it will then be flat. In fact, some folks prefer to use gloss colors in general painting because they do not need to use a gloss coating before decal application (decals should always be applied to a gloss surface). They then dullcoat the whole model to give a flat finish for military aircraft.
