airbrushing with acrylics
Posted by Anonymous on Monday, February 23, 2004 10:20 AM
I recently airbrushed using Tamyia's acrylic chrome silver and had some flecking. I was wondering since it is acrylic and it says it is water soluble, should I have thinned the paint with water first or was I right in using Airbrush thinner. If it is airbrush thinner to be used, is there an acrylic thinner or does airbrush thinner work for all types of paint?
Thanks
    October 2003
Posted by gwaihir on Monday, February 23, 2004 11:26 AM
I thin my acrylics with rubbing alcohol. It seems to be pretty commonly used (and cheap).Wink [;)]
Click the banner to see my builds.
    November 2003
Posted by Copterguy on Monday, February 23, 2004 12:13 PM
Howdy,
I've recently got back into modelling and have experimented pretty heavily sorting out my methods. I've had the best results thinning with the manufacturer's thinner. If I'm using Tamiya paints, I thin with Tamiya thinner; similarly with modelmaster paints, I'll use modelmaster thinner. I generally use a ratio of 2:1 paint to thinner for airbrushing. Hope this helps.
Jim
Current Projects: Tamiya M1A2 Tamiya LRDG Chevrolet CWT 30
    January 2003
Posted by plasticmod992 on Monday, February 23, 2004 12:15 PM
For Tamiya use Tamiya thinner, 70% rubbing alocohol, or water. Clean your airbrush with Windex. Tamiya can be sprayed straight without thinning, but for best results thin it a bit (approx 2 parts paint to 1 part thinner).
Greg Williams Owner/ Manager Modern Hobbies LLC Indianapolis, IN. IPMS #44084
Posted by Anonymous on Monday, February 23, 2004 1:12 PM
thanks for the info guys!
Posted by Anonymous on Tuesday, February 24, 2004 11:09 PM
Maybe you are shooting too much paint. Tamiya metallic paint can do that if you shoot too much.
