Painting Vacuform Canopies
    January 2013
Posted by B1Bob on Monday, December 9, 2013 5:19 PM
I am building my first aircraft in decades, a 1/72 North American T-2C Buckeye. I used a vacuform canopy which I dipped in future before installation. After gluing it on, I masked it. I first painted the canopy frames flat black. I then primed the entire model and put on a gloss white topcoat. After the other colors are done, I plan to apply decals and the a clear topcoat. After all that, I will remove the masking tape from the canopy. Question: If I have any paint bleed under the tape is there any way to correct the problem such as cleaning the canopy with a q-tip and windex or I am just going to have a nervous breakdown. Thanks!
Posted by Don Stauffer on Tuesday, December 10, 2013 9:28 AM
I scrape small spots with the tip of a #11 Exacto.  Any dulling can be fixed with more future.
To avoid bleed under, go over the edge of canopy masking with a bit of future.  The future will seal the seam and any bleed under of it will not be very noticable.
    March 2010
Posted by Nathan T on Tuesday, December 10, 2013 10:01 AM
If you use windex it will attack the future since you dipped the canopy in it. A toothpick can scrape away paint without damaging the canopy if you're careful.
