Primer and acrylics
    August 2012
Primer and acrylics
Posted by JMorgan on Wednesday, January 22, 2014 7:52 PM
Is is necessary to prime before you use acrylics?
    January 2014
Posted by Offduty on Wednesday, January 22, 2014 8:10 PM
I just read  Vallejo recommends to use primer on all there acrylics. I have used it both ways and it does cover better with a base at least on larger parts it makes a difference.
    November 2006
Posted by Bearcat57 on Thursday, January 23, 2014 12:59 AM
I strongly recommend a coat or two of primer before applying acrylics....unless you enjoy watching bits and pieces of your paint job come up along with your masking tape. I'm a big believer in priming regardless, as it's the easiest way to ensure the surface is as blemish-free as possible before the final paint job goes on.
    February 2011
Posted by Hokey on Thursday, January 23, 2014 6:44 AM
Do you airbrush or rattle can primer?
    August 2005
Posted by Phil_H on Thursday, January 23, 2014 7:04 AM
I primarily use Tamiya acrylics (airbrushed) and have never really had a need to use a primer.
However, when brush painting with Vallejo Modelcolor, I like to apply a primer coat (airbrushed) of a suitably coloured Tamiya flat acrylic.
Posted by Tojo72 on Thursday, January 23, 2014 8:15 AM
When I do prime,I use Tamiya Fine White Primer or Mr Surfacer 1200,both in the rattlecan
Posted by Don Stauffer on Thursday, January 23, 2014 9:59 AM
I think priming is a good idea whatever type of paint you are using.
    May 2012
Posted by pilotjohn on Thursday, January 23, 2014 1:29 PM
I always prime unless I am doing a cockpit interior or wheel wells which won't be masked.  My experience is that Model Master priming is a requirement as it has poor adhesion over bare plastic.  I did the wheel wells of my last 109 without priming using Vallejo Model Air acrylics and I tested the overspray on the wings with both Tamiya and Scotch Blue tapes and neither pulled it up.  No real experience with Tamiya as I only have used it on armor which I always prime.
I use Vallejo's acrylic polyurethane primers.  I have three colors; grey (which dries almost white), panzer dark grey and black.  You can mix them to get whatever shade of gray you need.
Better safe than sorry would be my recommendation.  As others have said, priming is useful in reviewing your work before the final coat(s).
John
    December 2011
Posted by Chrisk-k on Thursday, January 23, 2014 6:25 PM
I always prime with black Vallejo poly primers.  It also serves as preshading.
Iwata HP-CS | Iwata HP-CR | Iwata HP-M2 | H&S Evolution | Iwata Smart Jet + Sparmax Tank
    September 2012
Posted by Squatch88 on Saturday, January 25, 2014 6:13 PM
I usually prime all black before adding the final paint colors, I started doing it for preshading and found that the paints do stick better and no longer come up with the masking tape.
