Spray booth bathroom fan motor question.
    June 2008
Posted by Buster95 on Saturday, April 26, 2014 11:49 AM
Does anybody know if this motor is safe for a spray booth?
    November 2003
Posted by mississippivol on Saturday, April 26, 2014 7:02 PM
From what I understand about them, no.
    May 2013
Posted by Snibs on Saturday, April 26, 2014 9:00 PM
As long as its brushless as that is there's no ignition source just electromagnetic field, I use a old exhaust fan with the same motor. Not sure on the impeller though, just a fan on mine with a speed controller.
Mick.
Some stuff that might be interesting.
https://sites.google.com/view/airbrush-and-modeling/home
On The Bench.
Tiger 1 and Tooheys.
    June 2008
Posted by Buster95 on Sunday, April 27, 2014 12:00 AM
I'm far from an expert in electricity but I'm pretty sure this motor is brushless.
    May 2013
Posted by Snibs on Sunday, April 27, 2014 12:57 AM
it is indeed brushless.
On The Bench.
    April 2004
Posted by Jon_a_its on Sunday, April 27, 2014 9:51 AM
Not familiar with this model, & am puzzled as to how the fan will do 'owt more than distribute paint scatologicly?
Following Snib's airbrush page link above, I've seen several home-brew booths, with & without carbon filters, but characterised by the use of 4" or 6"  BATHROOM EXTRACTOR FANS, or IN-LINE fans
Caveat: the fans are rated as brushless (eg sparkless) and are IP44 (in the UK)  safety rated,
eg fans designed to shift wet/damp air with the motor not in direct airflow & capable of withstanding minor splashes.
There are also 12 volt fans rated as safe within shower enclosures available as well.
Your local safety regs may differ, but you only get 1 life, so 'lets be careful out there...'
East Mids Model Club 32nd Annual Show 2nd April 2023
 http://www.eastmidsmodelclub.co.uk/
Don't feed the CM!
Posted by Don Stauffer on Sunday, April 27, 2014 11:52 AM
The other problem is flow rate.  A spray booth requires at least 100 cfm.  Not all bathroom fans are this powerful.  Some are around 40 cfm.
    May 2013
Posted by Snibs on Sunday, April 27, 2014 4:42 PM
The fan in mine is 30 cm or 12 inch, it needs the speed controller to stop it sucking the furniture in Big Smile
On The Bench.
