Can I tint MM metalics or Floquil metalics?
Posted by echolmberg on Thursday, August 28, 2014 12:26 PM
Hi guys!
I've read about how some metalic paints can have a drop or two of gloss black paint added to it when highlighting some NMF panels.  Can Model Master gloss black enamel be added to the Model Master metallic line of paints?  I'm guessing the answer is no but I just wanted to verify my feelings on this.
What about paints like Floquil Old Silver or Silver Mist?  Can MM gloss black be added to tint these colors?
Thank you in advance!
Eric
    January 2014
Posted by Silver on Thursday, August 28, 2014 11:25 PM
Yet.Even gloss brown for exhaust areas.
    January 2014
Posted by Silver on Friday, August 29, 2014 8:40 AM
The only way to seal- gloss or flat the Floquil for a good result is to use non- spar varnish clear -flat or gloss.Thin30%
Posted by Don Stauffer on Friday, August 29, 2014 10:00 AM
While MM paints can be mixed easily with each other, I'd try a test with the Floquil. It seems to be like no other brand.  Seems almost more like a lacquer than an enamel, and the thinner sure smells funny.  Try a mix and paint some scrap plastic with it- do not use on a good model unless you run the test first.
Posted by Texgunner on Friday, August 29, 2014 10:24 AM
Yes Don, I do believe Floquil is lacquer-based paint.  I used to use Floquil thinner when I used it.   That is no longer available and the guys at King's Hobby in Austin said one could use lacquer thinner for the same result.
Gary
"All you mugs need to get busy building, and post pics!"
Posted by echolmberg on Friday, August 29, 2014 11:18 AM
Thanks for all the responses.  Gary, you actually answered the other question I had rattling around in my head.  I was wondering what I could use to thin Floquil.  I was starting to run some of the Old Silver through my airbrush and it just seemed to spit out.  It wasn't bad but it wasn't as smooth as other times when I used Floquil.  I was hoping that thinning it a tad would solve the problem but I think I determined that my airbrush just needed a good cleaning.
I ended up using MM metalics on my F-89 and for some strange reason, it's actually holding up perfectly in spite of all the panel masking I'm doing with it.  Granted, I'm "de-sticky-fying" it by using my fingers but not a single microdot of the MM metalic paint has lifted off.
I've said it before and I'll say it again.  99.999% of my builds involve pure luck more so than skill.
Eric
    January 2014
Posted by Silver on Friday, August 29, 2014 10:11 PM
Floquil is a heavy enamel base metallic paint that dries hard and can be masked w/ normal masking tape.Testors Metalizers can be used to creat panel shades .But; It is very hard to seal w/ flats and glosses.Even when you use Floquil sealers.Floquil is out of production and still out there to get because of a world wide stock left from the railroad guys.I use SN'J powder because I stocked up before they went out of production .I have about 100 assorted metallic powder bottles left.
    January 2014
Posted by Silver on Friday, August 29, 2014 10:15 PM
Mineral spirits to thin.
Posted by Texgunner on Tuesday, September 2, 2014 10:29 AM
I believe that Floquil is actually a lacquer-based paint.
