Suggestions on how to paint the base this way?
    February 2011
Posted by Hokey on Monday, November 17, 2014 3:35 PM
Not sure if AB painting lettering first then masking then AB surrounding topcoat or painting all then brush painting lettering?
 nautilusbrodeen1_02 by hotkey, on Flickr
    January 2013
Posted by BlackSheepTwoOneFour on Monday, November 17, 2014 8:51 PM
Would be easier to paint lettering last.
    February 2011
Posted by Hokey on Monday, November 17, 2014 8:58 PM
So just brush paint or mask and spray or?
    August 2012
Posted by AndrewW on Monday, November 17, 2014 11:08 PM
I'd paint your scheme, mask and spray on your lettering.  Maketar makes nice masks, die cut.  If you're doing light colors, remember, several light coats.  Masking and spraying looks far better than hand painting in the end, especially with small scales.
Life is hard, it's even harder when you're stupid - John Wayne.
    February 2011
Posted by Hokey on Tuesday, November 18, 2014 6:55 AM
Thx! How does that die cut mask work? Do I have to supply a model for them to create or?
Posted by Don Stauffer on Tuesday, November 18, 2014 9:19 AM
Making homemade (inkjet) decals of markings is an alternative to airbrushing them.
    February 2011
Posted by Hokey on Tuesday, November 18, 2014 10:56 AM
Don Stauffer
Don The lettering is cast in the resin base (I re-added the photo above). I'm trying to work out best way to paint the base and then the lettering a different color.
Posted by Don Stauffer on Wednesday, November 19, 2014 9:19 AM
Is  the surface of the lettering too rough for a decal?
    February 2011
Posted by Hokey on Wednesday, November 19, 2014 12:08 PM
It's pretty smooth.
    February 2011
Posted by Hokey on Monday, January 5, 2015 4:35 PM
OK - So I'm at this step of the process.  Please refer to photo above.
I bought some "Frisket Film" to try masking. Clueless on this!
From prior suggestions I Think I should paint the lettering 1st - no masking anywhere.
Then mask the lettering tops and paint the base coat light "aqua".
Then oil "wash" - picking up areas randomly.
Then spray flat acrylic top.
Seem right? I'm really a rookie modeler so could use any comments u care to share!
    February 2014
Posted by CN Spots on Monday, January 5, 2015 4:48 PM
If I'm looking at what I think I'm looking at...  the base is that large turquoise panel with a smaller panel on top that has raised letters on the smaller panel?  Why not paint the entire base the way you want it and go over the raised letters with a lino roller (think small, rubber paint roller)?  It will only deposit paint on the raised parts of the base.
    February 2011
Posted by Hokey on Monday, January 5, 2015 4:51 PM
CN Spots
That sounds like a cool approach!  Prolly get the roller at Hobby Lobby? Need a specific type of paint?
    February 2014
Posted by CN Spots on Monday, January 5, 2015 6:14 PM
They have paints for doing lino cut prints with but you could probably use anything. Just keep in mind that enamels will probably not come off of the roller so if you go that route, buy a disposable roller.  It will take quite a bit to coat the roller so you don't want to use your expensive model paints.
A trick to keep the roller from touching the base where there are large voids between letters/words is to use cardboard to roughly mask off those areas.  The roller will just roll over the cardboard and not touch the base.
    February 2011
Posted by Hokey on Monday, January 5, 2015 8:49 PM
Lol what initially sounded simple now sounds complex!!!
    April 2013
Posted by KnightTemplar5150 on Tuesday, January 6, 2015 1:45 AM
Have you considered using a paint marker for the lettering? Testors and Tamiya both make markers in a wide range of colors, including metallics. Airbrush the base, then simply run the marker over the raised lettering - no need for masking. Tamiya's line has fairly fine points and you can trim Testors to a size which is comfortable (or practical) to use.
    February 2011
Posted by Hokey on Tuesday, January 6, 2015 4:48 PM
KnightTemplar5150
I'm gonna try this - prolly tomorrow. Found a  Krylon gold pen at HL - Hope that works!
