Winter can really play havoc with modeling, especially painting. The area of my shop that is best insulated will get to 60 degrees plus using a propane space heater, but I view that as marginal, and it is definitely a bad idea to spray any solvent based material with a heater on.
What hasn't been said directly is that everything has to be as warm as you can get it; the paint, the AB, the model itself. Anything in the process that chills the paint affects the outcome. I can see from your 2014 review that you don't normally have any issues with painting, so it's gotta be temperature.
During the cold months I try to be content with building and shooting primer, and save the finish coats until spring. Hope this 2c helps & Happy New Year!
