Problem With Testors Model Master Flat Clear
    May 2012
Posted by pilotjohn on Thursday, March 5, 2015 9:02 PM
Can this product go bad?  I sprayed it over my model this evening and it is drying pretty glossy.  I am wondering what might have happened.  It is milky colored and still has a pretty strong odor.  Does it need to be shaken very well before application?  I usually use Vallejo Flat Varnish but I had a bottle of this that I wanted to use up.  Thx.
John
Posted by Texgunner on Thursday, March 5, 2015 11:08 PM
It should be well-stirred before use.
"All you mugs need to get busy building, and post pics!"
    May 2012
Posted by pilotjohn on Friday, March 6, 2015 9:13 AM
Thanks.  I wasn't sure about that.  I will try the last of it again.
John
    November 2008
Posted by plasticjunkie on Friday, March 6, 2015 2:13 PM
John
MM flat acrylic clear is milky white but dries clear. I like to thin it with the Universal acrylic thinner.   What I suspect is that the chemicals were not properly mixed and they separated in the bottle. You need to stir it  as Gary suggested.
 GIFMaker.org_jy_Ayj_O
Posted by Don Stauffer on Saturday, March 7, 2015 10:15 AM
Usually even thick coats of dullcoat dry quite quickly.
Awhile ago Testors did experiment with some enamel versions of both the dull and gloss.  Maybe you got that version.  Many of us did not like that version very much and I don't see it on the shelves now.
Posted by Texgunner on Saturday, March 7, 2015 10:19 AM
Just to be sure, this was Model Master "acrylic" flat clear, correct?  In the little round 1 oz. bottle?Smile
    May 2012
Posted by pilotjohn on Saturday, March 7, 2015 7:27 PM
Thanks for you replies.  I shook to daylights out of it and it worked fine.  Quite a smell compared to the Liquitex varnishes.  Same result though.
John
