Alclad clogging problem...what am I doing wrong?
    November 2004
Posted by jhawk on Thursday, March 5, 2015 10:32 PM
Hello:  I'm using Alcad paints for the first time.  I'm painting the exhaust area of a F-4 Phantom.  I first laid down Alclad's gloss black as a base coat.  I had no problems at all:  no clogs, paint went on smoothly and adhered well.  I'm now spraying Alclad's Aluminum paint using a Paasche H airbrush set to the recommended 12-15 psi and using a #3 tip.  My problem is that the tip clogs almost instantly.  If I pause for even 1-2 seconds, the tip clogs and I have to clean the tip with lacquer cleaner on a q-tip.  Even if I spray continuously, without pausing, the tip will eventually clog.
So, what am I doing wrong?  I have not thinned the paint as I read that you don't have too.  The paint is going down well, looks good, and is adhering well.
Thanks for any tips or suggestions.
    November 2003
Posted by tempestjohnny on Tuesday, March 10, 2015 7:44 AM
Do you have a filter in your paint cup?  If so metallic could be clogging it. I've never had an issue so just throwing out ideas
    March 2010
Posted by Nathan T on Tuesday, March 10, 2015 9:11 AM
Alclad will tip dry pretty quick. First, make sure your airbrush is 110% clean to start with. Sounds like your PSI is ok, 10-14 works good. What size is the pasche tip? I wouldn't go smaller than .3. .4 or .5mm is better. Also, make sure you've shaken the bottle real well so the pigments are properly dispersed.
    October 2007
Posted by Milairjunkie on Tuesday, March 10, 2015 9:21 AM
Alclad does need some pretty serious shaking before use & even when properly mixed it starts to separate / settle very quickly - I only put as much as I need in the cup & even when doing larger areas I will tend to use a few ml at a time in the cup & refill often. If it's settling in the cup, it's possibly that excessive settled solids are getting pushed through the nozzle & causing tip-dry.
Alclad also seems to like as little pressure as possible, if you can, maybe try dialling it back even further.
Just a couple of ideas, but it does sound like there could be a bigger issue.
