Primer on White Metal
    January 2013
Posted by jibber on Thursday, March 19, 2015 4:54 PM
Can anybody recommend a good primer for white metal. I'm working on a kit that has several parts and i was thinking that any automotive primer should work but any thoughts are appreciated.
Thanks, Terry
    December 2013
Posted by CodyJ on Thursday, March 19, 2015 9:17 PM
I made this one and used Tamiya Fine White Lacquer Primer and Acrylic Paint (Custom mix).  I cleared it w/ Tamiya Lacquer.  I suppose you could use etching primer though.  Just make sure its a fine primer or you will lose the details being a small 1/43.  I found the Tamiya white primer seemed to work very well.
This is what the can looks like TAMIYA WHITE
    January 2013
Posted by jibber on Friday, March 20, 2015 7:36 AM
Cody thanks I have a can on the shelf, thanks. Terry
Posted by Don Stauffer on Friday, March 20, 2015 11:48 AM
I use auto paint primer for metal bodies, like Duplicolor primer, but Rustoleum metal primer and Krylon primer work pretty well on bare metal.  For metal surfaces it is important to get all oil film off with detergent or solvent before priming.
    January 2013
Posted by jibber on Friday, March 20, 2015 8:21 PM
Thanks Don, the first thing I did was clean up all the parts but I just wanted to check on the primer due to the soft white metal. I think I should be all right. Thanks..
