Leaving an airbrush to soak
    July 2004
Posted by Virago on Thursday, March 26, 2015 9:48 PM
Does any one have any issues with leaving their airbrush tip down in water or cleaning solution during a paint session, I find that it could be 30 minutes or more between colour changes, and I don/t want to have to do a deep cleaning or worry about a clogged tip. If you were to pull the needle back a few millimeters and leave the airbrush tip down in a small jar with cleaner just up to the paint bowl, does anyone feel there would be any harm?
    December 2006
Posted by Fly-n-hi on Friday, March 27, 2015 12:12 AM
Maybe.  Depends on the solution.  Some thinners like lacquer thinner can damage parts that aren't made of metal.
    July 2013
Posted by modelmaker66 on Friday, March 27, 2015 12:43 AM
I just do a quick clean by wiping out the used paint and run windex through until clear. I use acrylics. It is ready for the next color then.
    March 2013
Posted by patrick206 on Friday, March 27, 2015 1:47 PM
I agree with Fly-n-hi, a few things to consider.
What make and model is the AB, where are the seals and O rings and what are they made of?
I suspect leaving it to soak would be a good way to prevent residual paint setting up, but may well cause serious damage to AB components, if they are not compatible with the liquid used for soaking.
When finished with one color I spray a rinse through the AB, wipe everything clean, spray more rinse through, then dis-assemble the front parts for individual cleaning, withdraw the needle for a good wipe down and I'm ready for the next spray application. Takes just a few minutes, but well worth the time as a preventative maintenance step to prevent AB damage, and to assure long service life.
A good quality AB can serve reliably for decades if given that extra measure of care, and perform like new as well. Just my thoughts.
Patrick
    February 2015
Posted by Bick on Friday, March 27, 2015 4:16 PM
What I do and YMMV. When finished with a color and NOT going to spray for some short (not overnight) time I put a little thinner in the AB, swish around, dump on a paper towel then put a little more thinner in and spray til clear, wipe cup with a paper towel, then put a little thinner in the cup, spay a little, place it in my holder and go about building. When ready to paint again I spray some of the thinner (already in the cup), change color and get on with painting. IF some paint has dried at the tip, I moisten a Q-Tip, cotton bud or whatever with thinner, withdraw the needle, swab the nozzle and then paint. Works for me but I use craft acrylics mostly.
    January 2015
Posted by Radial9 on Friday, March 27, 2015 5:24 PM
I watched an interview recently with the owner of Badger. He was asked the question. Absolutely no soaking was his reply. This guy owns a company that designs airbrushed and gets dozens in for replacement of bad seals. Also abhors stiff metal cleaning brushes. I'm taking his advice. I have started breaking down the front end and pulling the needle for cleaning between colors. He says its not necessary but sometimes I get pulled away from the bench between colors for many reasons. I just feel better having a clean AB sitting there for the next color or whatever comes to pass. He also mentioned there is never a need to disassemble anything more than the front end and needle.
    December 2011
Posted by Chrisk-k on Friday, March 27, 2015 5:51 PM
I use acrylics (mostly Tamiya). I sometimes leave my airbrushes (3 Iwatas) for 30-60 minutes between color changes and have never had a problem. After shooting a color, I just shoot IPA a couple times and leave IPA in the cup.
Iwata HP-CS | Iwata HP-CR | Iwata HP-M2 | H&S Evolution | Iwata Smart Jet + Sparmax Tank
    February 2011
Posted by Hokey on Friday, March 27, 2015 6:01 PM
Radial9
Where did you see the interview?
    January 2015
Posted by Radial9 on Saturday, March 28, 2015 4:05 AM
YouTube. "Interview with Ken Schlotfeldt"
    October 2007
Posted by Milairjunkie on Saturday, March 28, 2015 9:02 AM
Doesn't sound like a good idea, with water you would be OK, but you would have to be careful with any type of cleaner.
Solvent based cleaners would deteriorate any rubber seals (black) in the area & any cleaner at all may tarnish or eventually undermine the chrome or nickel plate through microscopic cracks / flaws in the finish & lead to the plate separating from the underlying brass.
Posted by Don Stauffer on Saturday, March 28, 2015 9:49 AM
One reason I like my Badger 200 and 150 is that they are all metal- mostly brass.  Except for the teflon washer that seems to stand up well to most solvents though I usually do not put that in the jar.  Anyway, I have had no damage from either in letting parts stand in either strong thinners (lacquer thinner and others) nor strong caustic detergents.
    November 2008
Posted by plasticjunkie on Sunday, March 29, 2015 8:19 PM
The only time I soak is just the tip off the AB for a few minutes. I use lacquer thinner in all 3 Badgers and one is 40 years old. I shoot the LT through to clean things in between sessions. I break the AB down for a good cleaning about every 4 or 5 uses.
The only time I had a needle bearing damaged was when I used Mr. Surfacer. I have used the Tamiya primer in my AB with no problems.
 GIFMaker.org_jy_Ayj_O
    January 2015
Posted by Radial9 on Monday, March 30, 2015 5:59 AM
I too will let the front end parts stand in a small tin of LT before swabbing with a cotton swab and reassemble. I did order an Iwata cleaning tray after multiple fun times chasing parts across the garage floor with a flashlight. Training my hands to STAY over the bench!
Plasticjunkie... is that 4 or 5 times colors in one day or will you let it sit for 4 days before breakdown?
I'm hesitant to leave the breakdown that long but knowing I could would be reassuring. Does the medium fit into the decision?
    November 2008
Posted by plasticjunkie on Monday, March 30, 2015 6:49 AM
Radial
No not in a day but sessions that may take several days or weeks. The only time I will break it down before several uses is if is not atomizing properly otherwise it gets several flushes only. The LT will easily dissolve everything including dried acrylic but NEVER soak the AB body cause it will cause damage.
This came directly from the Badger repair tech. I also asked him about using glycerin as a lubricant. He told me to dip the needle then wipe it leaving a thin coating. He said it lubricates the needle and keeps junk from sticking to it. So I went to the local CVS Pharmacy and got me a bottle for a couple of bucks and have been doing this procedure now.
Posted by Don Stauffer on Monday, March 30, 2015 8:49 AM
plasticjunkie
My Badger 200 is also just over forty years old!  These things are bulletproof!
    February 2011
Posted by Hokey on Monday, March 30, 2015 9:50 AM
plasticjunkie
Radial
Do you flush using LT too? Nothing else for flushing or tip soaking? LT for break down cleaning too?
What kind of LT? Just hardware store quart/pint?
Posted by Gamera on Monday, March 30, 2015 9:53 AM
Yeah, I left my GREX overnight in Simple Green to soak and it ate the rubber seals in the brush! Still works fine though, now paint leaks back into the body of the brush- annoying but usable. Still I'd recommend not making the same mistake I did!
    November 2008
Posted by plasticjunkie on Monday, March 30, 2015 11:59 AM
Hokey
Yes I use LT for flushing and cleaning cuz it removes even caked dried junk. Then I take a Q Tip and wipe the cup and any spills on the outside of the cup. I use the generic LT in the red and blue can from Home Depot.
    February 2011
Posted by Hokey on Monday, March 30, 2015 12:03 PM
plasticjunkie
Hokey
Thx and are you painting/cleaning acrylics?
    November 2008
Posted by plasticjunkie on Monday, March 30, 2015 2:02 PM
Hockey
I use acrylics, enamels and lacquer paints.
