acrylics and washes
    July 2013
acrylics and washes
Posted by steve5 on Saturday, April 18, 2015 12:44 AM
a quick question , can you use an oil wash over acrylic paint's . if not what do you seal it with . steve
Posted by Bish on Saturday, April 18, 2015 12:53 AM
Yes, no need to seal with anything.
    August 2005
Posted by Phil_H on Saturday, April 18, 2015 1:02 AM
I've applied oil washes over Tamiya acrylics without any problems whatsoever. I actually prefer to apply direct to flat paint without gloss-coating first.
    July 2013
Posted by steve5 on Saturday, April 18, 2015 1:06 AM
what do you mix your oils with guy's
Posted by Bish on Saturday, April 18, 2015 1:11 AM
I use standard white spirit, I believe its called mineral spirits in the US.
    July 2013
Posted by steve5 on Saturday, April 18, 2015 1:12 AM
I'm doing something wrong then , my wash just took the acrylic paint off , and I used white spirit
    August 2005
Posted by Phil_H on Saturday, April 18, 2015 1:24 AM
How long did you leave it to cure before applying the wash? Minimum 24 hours to allow time to fully cure.
    July 2013
Posted by steve5 on Saturday, April 18, 2015 1:27 AM
I take it then, I hour is a tad short.I shall clean the mess up and try again. thank's phil.
Posted by Bish on Saturday, April 18, 2015 1:29 AM
Ye, that don't sound right. white spirits should have no effect on acrylic paint. Acrylic paint is water based.
    August 2005
Posted by Phil_H on Saturday, April 18, 2015 1:46 AM
In the case of Tamiya acrylics, it's part water, part alcohol based, with a few other aromatics in the mix, so it is a bit vulnerable when not fully cured.
    July 2013
Posted by steve5 on Saturday, April 18, 2015 1:54 AM
live learn , cheer's guy's
