Model Master enamel ?
    October 2013
Posted by infofrog on Wednesday, February 3, 2016 6:55 PM
I'm building a ch 53 helicopter. OK
The paints I use is Tamiya reg paints and Alclad
This helicopter two main colors are not in Tamiya paints . I found a color mix . I need Tamiya 3 paint colors to make one color . Not sure a match
At my hobby shop they offer Tamiya and Model Master enamels
Well Model master enamel has the perfect match for these colors .
I never used enamels . Not sure if this project would be better to go with Model Master Enamels .
Here  will be my process .
Base Primer Alclad black primer . Cure
Would Model Master Enamel work ok ? I have a lot paint to do . Thats the main reason I'm thinking this maybe better paint  to use . This ch 53 is big .
Any advice which direction to go
Thanks
Rick
    May 2013
Posted by hogfanfs on Wednesday, February 3, 2016 8:30 PM
I have not used the Alclad primers yet, however I have used Tamiya liquid surface primer (which is lacquer based like the Alclad) and have sprayed MM Enamels over this primer with no issues. I will in the next couple of weeks be spraying the Black Alclad primer, then using MM Enamels on a Spitfire I'm working on.
Hope this helps a little.
 Bruce
 On the bench:  1/48 Eduard MiG-21MF
                        1/35 Takom Merkava Mk.I
    July 2004
Posted by stikpusher on Wednesday, February 3, 2016 8:30 PM
Model Master Enamels are good paints. I have never used them over Alcad primer myself, but I doubt you will have any problems as long as you give the primer time to dry and cure. Just curious, but which paint scheme are you painting your 53 in?
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    October 2013
Posted by infofrog on Wednesday, February 3, 2016 9:20 PM
Here is a photo below I took with my Iphone .. The Tamiya mixer are found on the internet ..
Model Master perfect match no mixing .. Never used enamels
Thanks rick
    October 2013
Posted by infofrog on Wednesday, February 3, 2016 9:22 PM
    January 2009
Posted by fermis on Wednesday, February 3, 2016 9:33 PM
You will want to use Testors thinners for the MM enamels. I have tried other thinners, and haven't found any that played very well with it.
    March 2013
Posted by patrick206 on Wednesday, February 3, 2016 9:38 PM
I have used MM enamel for many years, like it very well and will continue it's use. Some recommend the exclusive use of the Testors Universal Thinner, it sure can't hurt anything, but I think it's a bit over priced. I use DuPont enamel thinner, works identically, many times less expensive.
MM doesn't seem overly critical with regard to thinning, I generally start with 2/3 paint to 1/3 thinner, adjusting from there. Often I might thin it up to 50/50.
For cleaning the airbrush following use, I clean thoroughly with paint store lacquer thinner. Use care, to ensure you don't allow material to enter the air valve behind the needle bearing. When I clean I hold the AB inverted and facing nose down. Nothing can enter the air valve that way.
Use MM with confidence, it's good stuff.
Patrick
    October 2013
Posted by infofrog on Wednesday, February 3, 2016 9:42 PM
Thanks I like no mixing . I will pick up the colors tomorrow Rick
Posted by Texgunner on Wednesday, February 3, 2016 9:50 PM
I use enamels almost exclusively, Humbrol and MM mostly.  I think both are excellent paints but I use Testor's Airbrush Thinner for spraying both.  It seems to give the best results with fewest problems.  I clean up with regular paint store/hardware store paint thinner (mineral spirits).
Gary
"All you mugs need to get busy building, and post pics!"
    October 2013
Posted by infofrog on Wednesday, February 3, 2016 9:57 PM
Thank you I should bought them today . I hope next week to start the airbrush stage . Thanks again Rick
    July 2004
Posted by stikpusher on Wednesday, February 3, 2016 11:53 PM
I'm with Tex regarding MM and Humbrol enamels. Super results from both brands using the same method. And unless you are dead set on priming, you can skip that step with enamels on plastic. They have better adhesion properties than acrylics. And once dried and cured are far hardier against scratching and lifting when masking is pulled up.
       - Plankton
LSM
Posted by Texgunner on Thursday, February 4, 2016 12:02 AM
stikpusher
Yup!  Yes
    October 2013
Posted by infofrog on Thursday, February 4, 2016 5:34 AM
Thanks again Makes me feel better Rick
Posted by Don Stauffer on Thursday, February 4, 2016 9:33 AM
I use MM gloss black to undercoat Alclad.  Works fine.  With the Alclad polished aluminum, I have had comments that polished aluminum never really looked that good (not really true).  I use Testors enamels for everything except the NMF where I use Alclad.
    June 2006
Posted by SoD Stitch on Tuesday, February 9, 2016 7:07 PM
I second all of the modelers who say they only use enamels; in particular, I've been using MM enamels exclusively (well, except for one or two bottles of MM acryls) for the last 30 years (ever since Pactra stopped making enamels; anyone else remember them?). I agree, enamels tend to go on better than acryls, and they are definitely more durable than acrylics but, unfortunately, Testors dropped about 25% of their enamel line last year after they got bought out by Rustoleum (including Armor Sand, one of my favorites, Pale Green, and SAC Bomber Tan). I contacted Testors/Rustoleum about the colors getting dropped, and they said they still make them, but only in acrylics. So, I guess I'll eventually be using MM Acryls, whether I want to or not!
1/48th Monogram A-37 Dragonfly: 95% (so close!); 1/35th Academy UH-60L: 90%; 1/35th Dragon "Ersatz" M10: 75%; 1/35th DML E-100 Super Heavy Tank: 100%; 1/48 YF-12A, 95%; 1/48 U-2R: 90%; 1/48 B-58 Hustler: 50%; 1/32 F-117, 50%; 1/48 Rafale M: 50%; 1/48 F-105D: 75%; 1/48 SOS A-1H Skyraider: 50%; 1/48th Hobby Boss Su-27: 50%; 1/16th Revell Lamborghini Countach: 75%; 1/12th Otaki Lamborghini Countach: 25%; Tamiya 1/35th M3 Bradley Cavalry Fighting Vehicle: 25%
    January 2013
Posted by BlackSheepTwoOneFour on Tuesday, February 9, 2016 7:33 PM
SoD Stitch
You probably still can find it in enamel if you know where to look. Try Scalehobbyist, Squadron, Sprue Brothers, Hobbylinc, etc...
    January 2013
Posted by BlackSheepTwoOneFour on Wednesday, February 10, 2016 9:16 AM
SoD Stitch
I've found some Polly Scale colors (not the Floquil Railroad colors) and the harder to find Humbrol colors in SprueBrothers site. There's no way I was going to pass up on those.
Posted by Don Stauffer on Wednesday, February 10, 2016 9:20 AM
I think the handwriting is on the wall for us enamel users.  The trend really seems to be towards acrylics.  When I started modeling we used model airplane dope for paint, and the smell of enamels is nothing compared to that stuff, so I guess that may be why smell doesn't bother me.  The fact that my workshop is down in the basement doesn't hurt, either.
Also, a lot of peope these days fear the health aspects of enamels and lacquers.  I suppose I have cut a few years from my life by using those hot paints, but I will be 78 in a few months, so they can't be that bad.
In any case, I am resolved to learning how to use acrylics better.  My real problem will be on models needing gloss finishes.  I find it so much easier to get a good gloss with enamel compared to acrylics.  The glossy acrylics just don't seem to be that glossy.
    January 2013
Posted by BlackSheepTwoOneFour on Wednesday, February 10, 2016 10:36 AM
If anything, I'd love to see Aeromaster back on the market as well. They can still be found on eBay.
    November 2003
Posted by tempestjohnny on Wednesday, February 10, 2016 2:41 PM
The old Floquil military colors were great too. Running low on my stash
    June 2006
Posted by SoD Stitch on Thursday, February 11, 2016 2:13 PM
Yeah, I managed to score a couple of bottles of FS30277 "Armor Sand" enamel from a company called Kit Kraft last year; I don't think they had very many left, though (plus, those things only have a shelf life of about a year, anyway)! I figure they'll last me long enough to decide which color to go to for my German armor (I'll probably go with MM Dunkelgelb which is, after all, the "official" color). I suppose I could bow to the inevitable, and switch to acrylics, but then I'll need two of everything for painting; I will resist as long as I can!
    July 2004
Posted by stikpusher on Thursday, February 11, 2016 8:32 PM
If you must have 30277 in enamel, Humbrol still makes the shade. I forget the number, but they call it "Dark Stone". All is not lost yet.
       - Plankton
LSM
    June 2006
Posted by SoD Stitch on Tuesday, February 16, 2016 10:19 AM
stikpusher
Good to know! Thank you!
    July 2004
Posted by stikpusher on Tuesday, February 16, 2016 4:36 PM
God save the Queen and British model companies! Toast
       - Plankton
LSM
Posted by Texgunner on Tuesday, February 16, 2016 4:52 PM
stikpusher
Hear, hear! Bow Down
    January 2016
Posted by Sailor Steve on Tuesday, February 16, 2016 10:18 PM
Another vote for Model Master enamels. Ever since I used their "Field Drab" 30118 to paint my Curtiss P-1 back in 1977 I've been sold. I find enamels much easier to thin and to clean, and I've always kind of liked the smell. I have found myself using more acrylics lately, especially Mr Kit paints for World War 1 stuff, but I still come back to the enamels where possible. For me they're just easier to work with.
