testers no.1260 dullcoat over tamiya x22 clear ????
    June 2010
Posted by 5-high on Monday, February 8, 2016 5:14 PM
5-high here
Ive just applyed tamiya x-22 clear thin,d with x-20A . after i decal my model I plan to seal it with the same clear .  now my question is , is testers dullcoat ( no.1260) compatible with tamiya,s clear ????. this will be first time i used it .
thanks ..5-high
    January 2013
Posted by BlackSheepTwoOneFour on Monday, February 8, 2016 6:38 PM
I see no reason why you can't.
    November 2008
Posted by plasticjunkie on Monday, February 8, 2016 9:05 PM
I spray Testors Dullcoat (Lacquer) over Future and MM acrylic with no problems. Just make certain to let the Acrylic cure for a couple of days and spray light coats of the testors lacquer. The Dullcoat will dry almost instantly when lightly atomized and will not harm the acrylic.
With this said, it should act the same over Tamiya acrylic paints.
 GIFMaker.org_jy_Ayj_O
    June 2010
Posted by 5-high on Monday, February 8, 2016 10:43 PM
ok light coats ..got it .
thanks blacksheep ,plasticjunkieBig Smile
