Mixing Enamels
    March 2016
Mixing Enamels
Posted by cbion1 on Friday, March 25, 2016 4:47 AM
Hey guys,
i was wondering if anyone has had any success/issues mixing enamels from different companies. I used testors enamel as the base layer and want to use Vallejo enamels to do the detail work. Has anyone tried this?
Also will I encounter issues if I use acrylic on enamel?
    June 2015
Posted by OldGoat on Friday, March 25, 2016 11:56 AM
Vallejo is an acrylic water based paint.
Your topic title is misleading.
If you are referring to mixing colors to achieve new shades or tones, they are not compatible.
If you want to use one over the other, no problem as long as the bottom color is fully cured.  Most of us do that all the time.
Posted by Bish on Friday, March 25, 2016 12:03 PM
Ye, as Goat says, vallejo are Acrylics, i am not aware of tham having an Enamel range.
But in short, no, you will have no problem putting one on top of the otehr as long as the first layer is dry. In fact, its often recomended for many weathering techinques.
    May 2013
Posted by Greg on Friday, March 25, 2016 12:14 PM
I was confused too and did some Googling. Vallejo seems to have a water based enamal, whatever that means. It does not appear to be a product intended for plastic models though.
At any rate, the answer to your question is what Goat said and Bish confirmed.
Posted by Don Stauffer on Saturday, March 26, 2016 10:06 AM
There are indeed acrylic enamels and acrylic lacquers both.  Paint chemistry these days seems to be getting very confusing.
    May 2013
Posted by Greg on Saturday, March 26, 2016 11:52 AM
Don Stauffer
Indeed.
