My DIY Disposable Booth
    May 2016
Posted by Wesleycharlessmith on Monday, May 2, 2016 9:36 PM
I just finished my own DIY disposable paint booth today.  I call it disposable because it is just a cardboard box with add-ons and if it gets too grimey I will just pull my fans a light and get a new and improved box!
This is the box I started with.  I work at an auto parts store and it is a heavy duty cardboard box that antifreeze comes in.
Its a box
These are the two fans I used.  They both came out of an old computer and are brushless 12V fans.
I am a fan of my fans
I traced the outer edge of the fans to know where to cut the holes.
Tracing
Then I cut the holes inside the traced lines.  I wasn't concerned with having the fans flush mounted as the box will probably eventually be replaced.  I taped the edges of the fans down to get a good seal and hold them in place.
Fans in place
This is the light I mounted in the top.  It is a 12V LED light.  I choose this one because the fans are 12V as well so I can work from one power source.
Light it up
Inside view with fans and light mounted.
Inside view
Outside view with fans and light mounted.
Outside view
I used steel wire to build a frame for the filters to sit on.
Filter wire
I used an old pair of socks for the filters.
Stinky socks
Here it is all set up with the Monte Carlo I am working on in it.  I made the stand as well with a steel plate, solder, steel wire and aligator clips.
All done
It works really well and I did not spend a dime using stuff from around the house/work.  I would recommend a build like this to anyone as it is super easy and works really well.  Hope you enjoyed my build!
    May 2013
Posted by Snibs on Tuesday, May 3, 2016 4:37 PM
It wont get much simler than that.
Well done.
Mick.
Some stuff that might be interesting.
https://sites.google.com/view/airbrush-and-modeling/home
On The Bench.
Tiger 1 and Tooheys.
    February 2011
Posted by Hokey on Wednesday, May 4, 2016 8:59 AM
Please repost photos!
    May 2016
Posted by Wesleycharlessmith on Wednesday, May 4, 2016 9:42 AM
I will when I get home today.  Bow Down
    January 2013
Posted by BlackSheepTwoOneFour on Wednesday, May 4, 2016 9:42 AM
Don't see pics/photos either...
    October 2012
Posted by Geezer on Wednesday, May 4, 2016 10:09 AM
No pictures, here.
www.spamodeler.com/forum/index.php
Mediocraties - my favorite Greek model builder.
    May 2013
Posted by Snibs on Wednesday, May 4, 2016 3:38 PM
No pics in the post but the links work, just click on them.
On The Bench.
    May 2016
Posted by Wesleycharlessmith on Wednesday, May 4, 2016 3:48 PM
I jusr reposted with pics but waiting for mods to approve stove I am a newbie.
    January 2013
Posted by BlackSheepTwoOneFour on Thursday, May 5, 2016 9:23 AM
Meh.... creative on the cheap I guess. Just curious because I don't think 2 CPU fans each at 12V might not be enough to draw the fumes away - especially using socks as filters.
    May 2016
Posted by Wesleycharlessmith on Thursday, May 5, 2016 9:29 AM
I was worried about that too.  It pulls a lot of air though.  I tried to hang a towel over the front to keep dust or while drying but it kept getting sucked in the box. I can see the over spray getting sucked up too when I a spraying.
