Simple tip for handling/holding aircraft models while airbrushing
    December 2013
Posted by route62 on Wednesday, June 7, 2017 7:54 PM
I find that on some aircraft builds I need to airbrush all sides in one sitting.  Usually there is a place on the aircraft I can insert a rod or clamp or something to securely handle the model during painting without touching the actual model.
On some builds I an unable to find a good way to create a temporary handle.  For these I place the entire model into a clamp.  Using a clamp with rubber ends I can secure the model with just enough pressure that the model will hold with friction.
I have clamped it end to end or wing tip to wing tip, whichever works and secures the model for handling.  As I airbrush I gingerly move or tip the clamped model around to get to all sides.  I have even placed it on a lazy Susan.
Hope this helps next time you run into this.
    September 2003
Posted by checkmateking02 on Wednesday, June 7, 2017 9:43 PM
Novel technique!  Thanks.
    July 2014
Posted by modelcrazy on Wednesday, June 7, 2017 11:40 PM
Agreed. I had just such a dilima today.
Steve
Posted by Don Stauffer on Thursday, June 8, 2017 9:16 AM
I often cut up coathangers to get wire for this. In addition to putting it in propshaft or jet nozzle holes, I have bent it into u-shapes to put it in landing gear holes (I put in landing gear after painting).
    May 2013
Posted by Greg on Thursday, June 8, 2017 11:36 AM
checkmateking02
I agree. Thanks from me, too.
    January 2013
Posted by BlackSheepTwoOneFour on Thursday, June 8, 2017 2:44 PM
I agree it's a novel idea but.... (there's always going to be a but - LOL!!) what happens if for some reason the kit suddenly slips off and goes crashing on the floor while you're airbushing? Murphy's Law is always happens but hey, you never know what can happen.
    December 2013
Posted by route62 on Thursday, June 8, 2017 3:16 PM
I agree there is a risk it can slip.  If memory serves I have painted 7 aircraft like this and so far none of them have slipped.  The rubber ends on the clamp are key as they slightly depress from the pressure as the clamp is tightened.
As i reposition the model to spray a different side, I will put the airbrush down and using both hands, I gingerly reposition the clamped model.  I will also hold the clamped model standing tall, allowing to slowly twist the clamp in place as I spray.
