Airbrush side cup
    September 2017
Airbrush side cup
Posted by Pinkbooger on Tuesday, October 10, 2017 11:14 AM
Hi, this is the handpiece that I have for my airbrushing. I have not currently ever used it but I am in the process of buying everything I need to be able to. By the looks of it I am missing a cup of some kind. I think it takes a side cup. Where can I get a side cup that is compatible? Is there anything else missing that has to do with the handpiece?
"You underestimate the power of the dark side"
-Darth Vader
    October 2008
Posted by Don Wheeler on Tuesday, October 10, 2017 11:40 AM
It could be you need one of the cups on this page.
Don
https://sites.google.com/site/donsairbrushtips/home
A collection of airbrush tips and reviews
Also an Amazon E-book and paperback of tips.
    September 2017
Posted by Pinkbooger on Tuesday, October 10, 2017 11:47 AM
I am thinking the same thing. do you know where i can get one that is not in yen? lol
-Darth Vader
    October 2008
Posted by Don Wheeler on Tuesday, October 10, 2017 3:23 PM
Can't help you there.  I do notice that they take Paypal.  You might want to contact them.  You may have similar difficulty if you need any replacement parts.
Don
    January 2013
Posted by BlackSheepTwoOneFour on Tuesday, October 10, 2017 3:28 PM
Did you take the blue foam out of the box? It may be under there along with a hose, wrench, and guide. I can’t imagine an AB not come with any of those.
    September 2012
Posted by GMorrison on Tuesday, October 10, 2017 4:24 PM
My two cents. I looked at their page, and they are out of business. Parts available are limited to stock on hand and they'll be raising prices as stock reduces.
Now, that's all well and good, but until you understand everything you'll need, I wouldn't start buying any of it.
Here's a picture of your A/B with the cup.
Frankly, I have no idea what any of that stuff is, but it looks like there's a push button separate from the air control to regulate paint flow.
If I were you I would either (A) find out what you need from someone who has and likes their A/B, or (B) switch to something that has reliable parts and service like iwata or Badger. Again, just my two cents worth.
    December 2013
Posted by route62 on Tuesday, October 10, 2017 4:42 PM
I have an olympus 200.  Iwata bought the design rights from olympus years ago for many of the models.  Much of the iwata line is a direct copy.  Many parts swap exactly.
    September 2017
Posted by Pinkbooger on Tuesday, October 10, 2017 6:49 PM
I looked and there is no side bottle in the case. Now I have to find a side bottle or buy a whole new setup.
-Darth Vader
    September 2012
Posted by GMorrison on Tuesday, October 10, 2017 6:53 PM
Yes, it looks like there's a place for the cup cut into the foam but they didn't pull the piece out and stick in a cup. Like there was a "basic", and a "complete" version.
    September 2017
Posted by Pinkbooger on Tuesday, October 10, 2017 7:32 PM
-Darth Vader
    January 2013
Posted by BlackSheepTwoOneFour on Tuesday, October 10, 2017 10:22 PM
Was this airbrush bought used "as is"?
    December 2013
Posted by route62 on Tuesday, October 10, 2017 11:22 PM
If you have a *** blick art store near you, go there with your airbrush and see if an iwata or generic cup will thread in.  Most airbrushes use standard sizes and many cups will work.
Also tcp global makes generic size cups for $5. Order one of those and try it if the iwata one's don't work.  You can also go to your local hardware store and in the plumbing section are brass fittings in all sizes and shapes.  See if you can find an elbow shape that will thread in.  Then all you have to do is get creative on making a seal for the threads like Teflon tape or petrolium jelly or an oring.
If you find a brass fitting that works, now you know the thread pitch and you can go back to tcp global or the like and see if you can find the right cup.  Also Chicago airbrush may be able to help.  Email them.
Grex also makes general thread size cups.  See if these are at a local retailer, try one of their cups or go to your local ipms chapter meeting and ask the fellow members if any of them have cups you can try and see if they fit.
If you think outside the box and get creative and I am sure you will be able to make something work instead of buying another setup.  It's simply a threaded hole.
    September 2012
Posted by GMorrison on Wednesday, October 11, 2017 12:30 AM
But it's not, route. It's a port for an assembly that has a valve operated by a push button to open the paint feed.
    September 2017
Posted by Pinkbooger on Wednesday, October 11, 2017 6:52 AM
I do not know. This was given to me.
-Darth Vader
Posted by Wingman_kz on Wednesday, October 11, 2017 6:54 AM
What does the engraving on the side of the body say? I can't make it out in the picture. Is there a port on the right side of the body to attach a cup? There is no port on the left side and normally side feed brushes can have the cup on either side so there would be the same port on each side. The "button" that the other poster referred to in their picture is just a filler plug for the port on the opposite side from the cup.
Is there a small cut out in the top of the body ahead of the trigger?
    September 2017
Posted by Pinkbooger on Wednesday, October 11, 2017 7:06 AM
GMorrison
But the cup just provides the paint right? Does the cup itself have a valve or anything that is operated directly by the button? If the cup is essentially a straight hole some of his ideas should work right?
-Darth Vader
    September 2017
Posted by Pinkbooger on Wednesday, October 11, 2017 7:07 AM
Wingman_kz
There is a threaded hole on the right side for a side cup.
-Darth Vader
    September 2017
Posted by Pinkbooger on Wednesday, October 11, 2017 7:23 AM
route62
I sent out some feeler emails to the companies that you mentioned to see what they say and if there cups would fit. Any informtion they give will be helpful in resolving this issue. From what I have read the handpiece that I have is much better than those starter kits so I would prefer to keep it instead of buying a cheap kit.
-Darth Vader
    August 2017
Posted by M1ks on Wednesday, October 11, 2017 8:16 AM
Pinkbooger
If you can't find the part cheaper than 15GBP delivered, (not sure what that is in Dollars assuming you're stateside?)
Then it's cheaper and easier to buy a gravity feed double action brush from ebay or similar.
    September 2017
Posted by Pinkbooger on Wednesday, October 11, 2017 8:44 AM
If my converter was correct that would be $20 USD. Wouldn't that make for a really cheap brush? Or are the gravity feed double action brushes just cheaper?
-Darth Vader
    December 2013
Posted by route62 on Wednesday, October 11, 2017 9:46 AM
Upload a close up picture of the threaded side of the airbrush.  That can help decide if it is just a threaded hole (most airbrushes) or something different.  The point of gravity feed is just that, the paint flows into the airflow using gravity,  Pushing down on the trigger opens the air valve on the bottom of the airbrush, and pulling back on the trigger pulls the needle back, allowing paint to spray out the nozzle.  typically there is not a seperate valve opening and closing where the cup threads in.
A side cup works in the same way as a top mounted cup, gravity feed right into the airflow, the only difference is the side cup clears your field of view when using larger cups.
Also did a quick search about your airbrush and over at britmodeller someone found out that some grex parts fit so the cups may fit as well.  Here is the quote:
"Grex XN nozzles work with Olympos HP100b's if that helps; I've got one of each. watch the seal in the body of the O as it will likely be rubber; Grex teflon seals also fit. hope this helps JD"
Here is a link to your airbrush parts list.  The cup looks just like grex:
https://www.obeeliks.com/Onderdelen/HP101_spareparts.jpg
    September 2017
Posted by Pinkbooger on Wednesday, October 11, 2017 9:57 AM
I will get you that picture as soon as I can. Thank you for the Grex info. I actually emailed that company to see if they knew of any of their cups that might fit.
-Darth Vader
    September 2012
Posted by GMorrison on Wednesday, October 11, 2017 10:30 AM
You'd better look at a few other factors too.
You need a hose that has the right fittings at each end for both the brush and your compressor. That's probably not too hard since it's based on Iwata, but on the compressor side you need something that is interchangeable at the regulator fitting with other brushes/ hoses.
And pick up extra needles and tips because they are out of production.
Sometimes things that are "free", are not.
    December 2013
Posted by route62 on Wednesday, October 11, 2017 11:28 AM
No need to worry about the hose size.  Olympos uses standaed 1/8" fittings.  These are widely available.  I would recommend a quick disconnect to make things easier.  You can get a standard airbrush hose with 1/8" on airbrush side and on compresser side it will depend on your compressor, most airbrush compressors use 1/8" but if you are using a compressor meant for air tools then you will need 1/2" fittings found at all stores that sell air tools.
The nice thing with olympos is that it uses all standard sizes unlike paasche and badger and other makes.
    January 2013
Posted by BlackSheepTwoOneFour on Wednesday, October 11, 2017 11:45 AM
By the time
GMorrison
That ^^^^
Sometimes free isn't worth the trouble unless you knew it wasn't a "complete set"
By the time you spend all your money and the aggravation in finding missing parts, you could would have been better off buying a brand new AB. Hobby Lobby got some airbrushes and with a 40% coupon, it's a great deal.
    September 2017
Posted by Pinkbooger on Wednesday, October 11, 2017 12:13 PM
So I am on my phone so I will post the pictures when I get a computer. But from what I saw there is no thread on the side of the airbrush.
-Darth Vader
    September 2017
Posted by Pinkbooger on Wednesday, October 11, 2017 3:24 PM
-Darth Vader
    December 2013
Posted by route62 on Wednesday, October 11, 2017 4:01 PM
This style is a compression/friction fit cup similar to the way the cups are fitted to airbrushes at the bottom, siphon feed.  The cup is tapered so that it stays on with friction.  The cup you are looking for has a metal tube that comes out the side and has a collar that would press on and around the knured portion while the tube goes inside the hole.
These cups are harder to find since most went to the threaded style.  Iwata still makes cups similar to this without the collar but it may still work.  Heck a bendy straw would work if you could keep it from leaking.  Basically you need a cup or elbow tube that will press fit in and not leak, perhaps with an oring.
This one may work, just use upside down and remove the straw:
http://www.tcpglobal.com/ABDTB-007.html#.Wd6Ht1tSyUk
Or maybe one of these:
http://www.ebay.com/itm/Badger-1-8oz-Color-Cup-Model-100-Side-Feed-Airbrush-Accessory-50048-/272853096957?_trksid=p2385738.m2548.l4275
Another to check:
http://www.ebay.com/itm/Iwata-Side-Feed-Bottle-Good-For-Siphon-and-Gravity-Feed-Cups-1-Ounce-I4501S-/132342097957?epid=1703564854&hash=item1ed0342825:g:kjoAAOSwAv5Zyq4B
Blick art stores carries the iwata line with many of the cups.  Go to a store near you and try one out.  Pour water in it and see if it leaks before buying it while at the store.
    September 2017
Posted by Pinkbooger on Wednesday, October 11, 2017 4:26 PM
The closest Blick art store is an 1 hour an 43 minutes away. Lol
Do you think it would work as a siphon?
-Darth Vader
    October 2008
Posted by Don Wheeler on Wednesday, October 11, 2017 4:33 PM
The people at Coast Airbrush are very knowledgeable about most brands.  If you call them and explain what you are looking for, there is a good chance they will know if something currently available will fit.  And, if there is, there is also a good chance they carry it.
Don
