Best gloss coat for weathering over
    July 2013
Posted by modelmaker66 on Saturday, April 7, 2018 2:34 AM
Hi!
What in your opinion is the best gloss coat product to use over acrylic to seal before using oil paint for weathering or using enamel weathering products. Something really bullet proof but allows the products to flow well and be wiped off easily.I have been using future but have seen others use tamiya gloss an even Mr. Hobby color gx-100. I airbrush my gloss coats on. Thanks.
Posted by Tojo72 on Saturday, April 7, 2018 4:13 AM
I have been using Alclad Aqua Gloss lately,really easy to use and clean up.No problems so far.
    December 2017
Posted by drumsfield on Saturday, April 7, 2018 9:30 AM
Someone said on youtube (he was an alcad spokesman) that aqua clear was basically the same as Future. I'm wondering how true this statement is. I'll link the video below.
https://youtu.be/bDZqwW9yFLU?t=699
    July 2004
Posted by stikpusher on Saturday, April 7, 2018 5:50 PM
If you’re going to be using oil or enamel weathering products, you’re going to want to use an acrylic gloss. My preferred brand for that is Future. But there are others out there that I can not vouch for or against.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    October 2010
Posted by hypertex on Saturday, April 7, 2018 7:56 PM
drumsfield
I think you have completely misunderstood what the speaker said. What he said was "that [Aqua Gloss] nullifies paying any stupid money for Johnson's Klear on Ebay or buying anything else. This stuff is simply the best." At no point did he say it was "basically the same" as future, nor does he come anywhere close to saying that. In fact, he is saying his product is better than Future.
Chris
    January 2017
Posted by damouav on Saturday, April 7, 2018 11:17 PM
I have attempted to use Aqua Gloss on several projects with less than stellar results.
I have, in a previous post likend it to wet snot, appologies for the rather untasteful analogy.
I don't have access to Future, so, I will continue to use Testors Gloss or Dullcoat untill a suitable alternative makes it self evident.
I have been meaning to try out Tamiya's X-22, from others experiences with the product it meant to be bullet proof when correctly applied and cured.
Good luck.
In Progress
1/48 Tamiya P47-D Bubbletop
1/48 Hobby Boss TBF-1C Avenger (on hold)
Pending
1/48 Roden S.E.5a
1/48 Airfix Walrus
Posted by Don Stauffer on Monday, April 9, 2018 8:36 AM
damouav
Good luck.
I also use Testors lacquer clearcoats- they are my goto for weathering over.  I use mostly enamel and lacquer paints, but I have friends that say they work okay over acrylics if the later are thoroughly dry.
    September 2012
Posted by GMorrison on Monday, April 9, 2018 10:04 AM
Reminder that the OP was looking for a barrier coat over which to use oil paints. That in turn means thinned with mineral spirits.
I’d be pretty hesitant to use spirits over a lacquer coat.
    September 2006
Posted by the Baron on Monday, April 9, 2018 12:31 PM
modelmaker66
...What in your opinion is the best gloss coat product to use over acrylic to seal before using oil paint for weathering or using enamel weathering products. Something really bullet proof but allows the products to flow well and be wiped off easily.I have been using future...
Why change, then, unless you just want to try something different?  I use Future, too, as my gloss coat, and I use washes of oils and mineral spirits over it, without any problems.
