Alclad gloss black base color issue
    September 2011
Posted by falconmod on Monday, February 25, 2019 10:28 AM
Has anyone ever had the gloss black Alclad base color be sticky after spraying it on?
John
On the Bench: 1/72 Ki-67, 1/48 T-38
1/144 AC-130, 1/72 AV-8A Harrier
    September 2014
Posted by rooster513 on Monday, February 25, 2019 10:45 AM
I've never sprayed it myself but I've heard of a lot of people having it not cure or taking a very long time to cure.
-Andy
Posted by keavdog on Monday, February 25, 2019 12:32 PM
I've used it a couple times without issue.  They reccomend letting it dry for 7 days.  I have had success spraying sooner than that thoug.
Thanks,
John
    September 2012
Posted by GMorrison on Monday, February 25, 2019 1:16 PM
falconmod
John
Yes, I have had that problem. I get good results with the Gloss Black Testor's in square bottles.
    May 2013
Posted by hogfanfs on Monday, February 25, 2019 1:19 PM
I've used it once, and did not have that issue. I did let it cure for 2-3 days.
 Bruce
 On the bench:  1/48 Eduard MiG-21MF
                        1/35 Takom Merkava Mk.I
    September 2011
Posted by falconmod on Monday, February 25, 2019 1:20 PM
Thanks for the info,   I guess I'll let it cure for a few days and see what happens.   I may need to polish that alclad base cuz it came out a little pebbly looking,  Do you think testers acrylic gloss black will go over it ok?
John
Posted by Don Stauffer on Monday, February 25, 2019 4:39 PM
Yes, it takes at least as long to dry as Testors enamel.  Since I keep gloss black Testors in stock, I just use that- never finished the bottle of the Alclad stuff.
    January 2013
Posted by BlackSheepTwoOneFour on Monday, February 25, 2019 6:26 PM
Or use gloss black in a rattle can. Spray in several light coats. Dry time is much shorter than Testors enamel.
