Acrylic - Waterbased right ? Well,what's with using Lacquer Thinner and Alcohol in it ?
    June 2014
Posted by Tanker - Builder on Friday, August 2, 2019 11:58 AM
 Hi;
     Now do you understand why I hate the stuff? All I see is folks talking about using all kinds of stuff I would never use in paint, much less in my shop ! Enamel uses Mineral Spirits just fine .
     It seems with each of the different brands you guys and ladies that use Acrylic are using a witches brew of stuff to thin it for spraying. Brushing? Fuggedaboudit !
 Besides, Most I've used just doesn't cover well. If I have to go there, where's my good old Polly S? One coat covers well and no brushmarks either! As a matter of fact Polly S was the paint I learned to use Both types of airbrushes with .
  I have recently read of a person using Clean Strip as a thinner, Really? I use that to remove paint ! Finished Ranting and Raving. I'll go back in my corner now .
    April 2009
Posted by Cadet Chuck on Friday, August 2, 2019 12:46 PM
And from the opposite corner comes another rant:  Acrylic is water based.  Water thins it very well.  Or you can use the manufacturer's matching thinner, IE Tamiya X-20 with Tamiya acrylics.  I say none of that other stuff mentioned, should ever be used for this job.
    July 2013
Posted by modelmaker66 on Friday, August 2, 2019 1:12 PM
Tamiya can be thinned by water, their own acrylic thinner which is alcohol based, IPA and lacquer thinner. How can you not love the paint that can do all that, covers great, sprays great and is cheap too? Enamel is slowly going away no matter what anyone prefers and that is just the way it is. Companies cannot afford to make acrylic that most buy and also make enamel that is not selling as well.
    November 2018
Posted by oldermodelguy on Friday, August 2, 2019 2:42 PM
As to Tamiya and from the Tamiya web site, their acrylic can be thinned with their X-20 or with their lacquer thinner. I thought if it can be thinned with their lacquer thinner it can be thinned with any lacquer thinner but maybe with a different end result. At the time I started using them I had Klean Strip on hand and it's sprayed great with that till my little incident yesterday which turned out to be user error. Tamiya states outright that the paint will dry harder with lacquer thinner than with X-20 ( can be confirmed, just read their website). Recently I've been in email communication with another forum member from another site who can not use lacquer products and having heard about good results using Tamiya acrylic paints thinned with 91 ipa from this site,  I decided to try that and report back to this guy. I can only describe my result as compared to lacquer thinner ( using ipa was new experiment to me even a month ago). My experience is it sprays similarly, dries very smooth smooth with very slightly less gloss. It produces what I think is a very period finish, shot that way, for classic cars, where with lacquer thinner it's more a wet look finish ( speaking about high gloss paints here).'This guy builds model cars from the 50's or so era and he had bought some Tamiya paints then was afraid to use them because he thought they were lacquer clean up..
Tamiya is a kind of hybrid acrylic. It sprays very much like enamel when thinned with either ipa or lacquer thinner but dries very fast. I also use some of their flat paints that shoot well too. And it cleans up with water and or alcohol or lacquer thinner. I won't speak about shooting it with water as thinner, I have not done that. I have however shot it with my own thinner I make up for 3 brands of crafts paints and also use in MM acryl. It shot perfectly fine with that but glosses dry with a slight haze in them, kind of like Dupond Centari acrylic enamel dried back in the 70's early 80's shooting 1/1 before they came out with their hardener catylist additive..
The down side to Tamiya acrylic is there are just so many colors, now I'm not adversed to mixing personally but some are turned off by that.
My transition to acrylics moves forward, I'm getting great results at this point from several brands and getting a good handle on thinning them..
    July 2004
Posted by stikpusher on Friday, August 2, 2019 3:05 PM
modelmaker66
For airbrushing, Tamiya is hard to beat.  But their paint line is very generic in color selection, requiring lots of mixing to create many commonly used standard military colors. Cost is certainly better than many competing paint lines.  But as far as handbrushing goes, straight from the bottle, for anything more than small details, be ready for challenges. I’ve been using the stuff since it was first released back in the day and before the formula was changed. It used to handbrush a LOT more easily straight from the jar. Especially over large areas.
 But folks, for both enamels and acrylics, I highly suggest that you look at Humbrols for whichever type you prefer. I’ve been very happy with those. Their enamels can’t be beat, and their new acrylic line is pretty darn good too!
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    March 2013
Posted by patrick206 on Friday, August 2, 2019 3:17 PM
For several years after acrylic paints showed up, I stuck with enamel. I heard stories about it at the hobby shop, heard about all of the witches brew thinning methods, and if you let it set up for just a few minutes in the airbrush it was ruined forever, impossible to clean then. Pfffft
A few years back I bought a couple of bottles of Tamiya, just to try it. Almost instantly I came to be comfortable with it, and indeed the airbrush can be easily cleaned after use. I started thinning with X-20A, then Tamiya lacquer thinner, finally with IPA. All work well.
My only MINOR issue with it, is that name brand lacquer thinner does clean the parts up a bit better/faster than IPA. Otherwise, I'm nearly an exclusively acrylic airbrusher now, with only a little use for enamel.
I get really nice finishes, I think superior to enamel, and if I do see a need for a little touch up now and then, it sands and receives the new layer perfectly.
In the end, what really makes the most positive difference for me is the absence of smell. Even with a very positive air flow spray booth, that discharges through a 4 inch hose and wall vent to the outside, enamel paint and thinners had a very noticeable and unpleasant odor.
But we like what we like, for some, acrylic is the "magic elixer," for others it's enamel. For the enamel users, I feel bad that so many of that type are going away. It's not easy to lose products that work for you.
Patrick
    April 2009
Posted by Cadet Chuck on Friday, August 2, 2019 4:29 PM
Dumb question:  What is IPA?  (I am thinking India Pale Ale, but I know that's not right in this context.)
Posted by Bish on Friday, August 2, 2019 4:39 PM
Cadet Chuck
Isopropyl alcohol
Just to throw another one into the mix, i use un-diluted car screen wash to thin Tamiya. A UK brand that was recomended by Geoff Coughlin in his Osprey book on Luftwaffe Fighter modelling. Works a treat.
    July 2004
Posted by stikpusher on Friday, August 2, 2019 4:45 PM
Cadet Chuck
Isopropyl Alcohol. Theoretically it should be IA... but you know how folks on the internet love to create their own shorthand. I’m with you on IPA being India Pale Ale. I don’t think that it would thin paint very well, and I sure would not waste IPA for that tasking if it did. Personally the IPA that I’ve enjoyed the most was brewed by Sam Adams.
But seriously, is it that hard to type up a word? There are too many competing identical acronyms out there.
       - Plankton
LSM
    April 2009
Posted by Cadet Chuck on Friday, August 2, 2019 8:19 PM
Here in Colorado, there are hundreds of craft breweries, and I have enjoyed sampling IPA's from many of them.  There are too many, to find and try them all!  This is a great place for beer afficianados.  Skoal!
    April 2019
Posted by John 3:16 KJV on Friday, August 2, 2019 9:56 PM
So, acrylic paints... Is water or alcohol the correct thinner/airbrush cleaner; or do both work? If the latter, which works better? I tend to be an enamel person myself... :)
     “For God so loved the world, that he gave his only begotten Son, that whosoever believeth in him should not perish, but have everlasting life.
     For God sent not his Son into the world to condemn the world; but that the world through him might be saved.”  - John 3:16-17
    December 2018
Posted by Ted4321 on Friday, August 2, 2019 9:57 PM
Does 70% "IPA" cut the mustard? I got a whole bottle and it seems the tamiya acrylic thinner is sold out everywhere.
Dang, I'm thirsty all the sudden.
T e d
    July 2004
Posted by stikpusher on Friday, August 2, 2019 11:16 PM
John 3:16 KJV
It depends upon the brand. Some acrylics thin well with isopropyl, others turn into a gummy blob when mixed. Experiment in a safe container/cup before you try it in your airbrush. There is no one size fits all thinner with acrylics. Many work poorly with water as a thinner. They will spray, but have an extended drying time, will run, bubble, pool, etc. Water is a poor cleaner for acrylics. But winded or other ammonia based cleaners work great as an airbrush cleaner for acrylics.
Enamels on the other hand are pretty consistent. They all thin with enamel paint thinner.
I work with both.
       - Plankton
LSM
    September 2012
Posted by GMorrison on Saturday, August 3, 2019 12:35 AM
Words of wisdom, Carlos. Words of wisdom.
Acrylic paints sold for scale modeling are NOT water based. Back in the day Polly Scale did work as thinned with water, but that's no longer available.
Modern "acrylics" are polymer based and while (some) are able to be thinned with water, it's not a given.
I personally dislike Tamiya paint.
The future seems to be air-brush ready acrylic paints like AK or Valleo Air.
Yes, enamel paints seem to be the most reliable for solving hardness, resistance to lift-up by masking.
Most Lacquer Thinner sold is in no way a thinner; it's a solvent. And the usual stuff sold at "Ace" et al is garbage,
Tanker- I have a collection of Polly paints that I use like a fine wine. Engine Black, Steam Power Black, Concrete. Under lock and key.
    August 2005
Posted by Phil_H on Saturday, August 3, 2019 1:42 AM
GMorrison
By definition, acrylic refers specifically to the type of polymer that forms the film of the paint. It in no way relates to the thinner/reducer that the particular paint uses. This may be (largely) water, alcohol or some other chemical cocktail specific to a particular brand.
Tamiya and GSI Creos Aqueous (aka Gunze) can be thinned to an extent with water, but also can be thinned using their proprietary thinners, which are essentially a water/alcohol blend, IPA or denatured alcohol, either of their proprietary lacquer thinners or a generic lacquer thinner.
GSI Creos also has the "Mr Color" range, described as  "solvent based acrylic" which can't be thinned with water or alcohol, instead requiring a lacquer thinner (either their own, Tamiya's or a generic LT) Put water or alcohol in this paint and you're going to have a bad day.
    November 2018
Posted by oldermodelguy on Saturday, August 3, 2019 6:17 AM
GM has stated that hardware store lacquer thinner is garbage. I would add that depending on the area or zone you live in, it also could be a new so called green or green friendly formula that has been reported by some modelers to work lousy in model paints of all types. If you are lucky, that is not the case in your area and you just have the regular garbage. But Tamiya paint happens to like that garbage, sprays very well with it and the garbage costs a fraction of Tamiya's own possibly ultra superb lacquer thinner or possibly repackaged garbage.. We don't know. Now all kidding aside, we know there are better lacquer thinners out there but if it works it works.
When I shoot lacquer I mix some xylene in with the hardware store lacquer thinner, this helps flow and aids gloss retention. It just slows the dry a little, you get less dry coating and can back the ab up a little bit.
Incidentally, on the package label someplace ( tiny print) of Klean Strip lacquer thinner it states that it's a medium dry thinner. I used Dupont medium dry thinner in 1/1 painting decades ago. You will never get a fast dry thinner to go on wet enough, especially in warm dry climates and probably still want to slow the medium dry down a little bit when shooting lacquers. Just fwiw.
Posted by Don Stauffer on Saturday, August 3, 2019 6:56 AM
oldermodelguy
Depends on the brand.  I have found more problems with enamel thinner than lacquer thinner.  Some brands are synthetic and have residual particulate matter in it. It  changes shade of the color.  For enamels I only buy the stuff that says either mineral spirits or turpentine.  I have used MEK to thin lacquers, but prefer to stick to lacquer thinner.
    November 2018
Posted by oldermodelguy on Saturday, August 3, 2019 7:24 AM
Don Stauffer
I recently bought a new can of Klean Strip lacquer thinner, it looks like the old can and the thinner smells the same but I haven't used it yet. I believe though that both that and the synthetic are on some shelves locally. I paid a little more at the hardware store down the street for this can than at HD home improvement store but believe I got the original formular which has worked fine for me all along. I keep the same brand xylene and also mineral spirits on hand. I also have their paint thinner which isn't very good for use in model paints.
    July 2004
Posted by stikpusher on Saturday, August 3, 2019 8:30 AM
I have a several years old can of Kleen Strip purchased at the local Ace Hardware that works just fine. But I pretty much use it for three things: 1, cleaning my airbrush occasionally; 2, thinning for Tamiya paints for airbrushing where I want a more rapid drying time; 3, periodic cleaning of paint brushes when paint build up in the base of the bristles becomes noticeable.
I like to use generic paint thinner strictly for cleaning my paint brushes after enamel paint use, and for immediate after enamel use painting in my airbrush.
For airbrushing enamels, I’ve had best results using Testors Universal enamel airbrushing thinner. It seems to give enamels more bite into the plastic over other thinners.
       - Plankton
LSM
    November 2018
Posted by oldermodelguy on Saturday, August 3, 2019 9:24 AM
stikpusher
Ya the Testors universal enamel thinner is a good blend. I don't worry about bite into plastic though because I tend to prime. As such I thin Testors enamels and their MM enamels with either lacquer thinner or with Mineral spirits. I haven't bought the Testors thinner in decades now but it always was a good product. They have it down at my local HS . Since I'm shooting less and less enamels these days ( and I was an enamel fan too, especially Pactra back in the day) I haven't looked back to that thinner. By the same token since I shoot so little enamel I suppose a new can of the Testors thinner would last me a long time @ almost $9 a pint.
    November 2018
Posted by oldermodelguy on Saturday, August 3, 2019 12:24 PM
GMorrison
[quote user="GMorrison"]
What don't you like about Tamiya paints if you don't mind my asking ?
To me there are other paints that I believe get the job done with a thinner film thickness.  But as far as ease of use Tamiya is pretty user friendly imo. I'm not a full convert lol !
    April 2019
Posted by John 3:16 KJV on Saturday, August 3, 2019 1:09 PM
stikpusher
John 3:16 KJV
I work with both.
Thanks, Stik! Do you (or does anybody) know what works best for thinning Testors/Model Master Acrylic paints (and for cleaning the airbrush after using them, too)? How about thinners for Vallejo Acrylics? I know there are acrylic thinners including a Testors one; but you can’t just buy a gallon of that like you can with mineral spirits for the enamels...(or can you?). Either way, is there a cheap alternative that works well?
    July 2004
Posted by stikpusher on Saturday, August 3, 2019 1:53 PM
I haven’t airbrushed Vallejo, so I can’t say anything from personal experience about thinning that brand. As far as Model Master acrylics go, I have only used their thinner with their paint. At least that can be had at Hobby Lobby with the 40% off coupon, so it’s not too costly. And the Model Master acrylic airbrush cleaner is excellent. It removes both enamel and acrylic paint off pretty much any surface, no longer how long that it has been on there. I have yet to come across a satisfactory inexpensive or generic thinner for Model Master acrylics.
       - Plankton
LSM
    November 2018
Posted by oldermodelguy on Saturday, August 3, 2019 6:17 PM
I've not had a problem shooting MM acryl with my own thinner blend. Especially the flats. Maybe I'm just lucky.
    July 2004
Posted by stikpusher on Saturday, August 3, 2019 8:41 PM
oldermodelguy
If your own concoction works, you’re doing great. What is one of Murphy’s Laws of Combat? If it’s stupid and it works, it ain’t stupid.
So what is your own thinner blend? That is, if you’re willing to share...
       - Plankton
LSM
    November 2018
Posted by oldermodelguy on Sunday, August 4, 2019 5:29 AM
stikpusher
I actually made it up for use in craft paints, it works in three or four brands of that ( keep it away from DecoArt though, the alcohol gels DecoArt). So I decided to try it in MM and it seems to go down quite well. 60% distilled water, 40% 91 ipa, and for every 3oz of this, 8drops of retarder of which I use Liquitex retarder because that's what I have on hand for shooting my wifes ceramics. The retarder is subject to your climate, in the winter here the air is dry and I up the retarder to 10 drops. Spring and fall is cool and damp, 8 will work but 6  might be better. The retarder pretty much stops tip dry and it slows initial dry or so called dry to the touch a little bit. I cook my paint jobs anyway so can't comment on long term dry time changes, pretty much an hour in the cooker and you can do what you want with it from there. If you have too much retarder for the conditions shot in, a hair dryer cures that. Too little and you might get a little tip dry.
    November 2018
Posted by oldermodelguy on Sunday, August 4, 2019 7:29 AM
Ted4321
T e d
It will probably work, your gloss finishes might have a little haze in them (most likely). That said 91% is cheap at your local drug store or cheaper yet at Wally World. But I'd shoot a little with that 70% in it and see if you like it.
    June 2014
Posted by Tanker - Builder on Sunday, August 4, 2019 8:33 AM
Oh-Ho !
       I wondered if I was the only one. I have at least twenty bottles in Railroad colors and Aircraft colors for the odd Rail or Air project requiring these. Otherwise, like you said, Under lock and key in a cool dark place. It still works well after all these years even as old as it is. Some shelf life that. I do keep it well mixed though .
       The thing that gets me though " G " is the lack of brushability of most of the new acrylic paints straight out of the bottle. Now there are some folks,  that Cannot in reality airbrush. Their living conditions do not allow for this . When I was in a Re-Hab facility after my heart surgery I couldn't airbrush, But I could go to the rec. room and brush-paint a project.
    Because two ribs snapped along with the large line on my frontispiece I had to do six weeks of therapy. I sure couldn't build or detail at this time when I could get out of my room. Enamels weren't allowed because they were flammable and so there you go.
     Now as far as using IPA in paint,wouldn't that give it a weird smell? That ( India Pale Ale) belongs in the tummy, Not in paint, right ?
    November 2018
Posted by oldermodelguy on Sunday, August 4, 2019 1:14 PM
My wife brushes acrylics all the time, she doesn't airbrush which is why I do the clear coat for her. But she uses an artists tray, blop a little paint in one of the wells and thin it a little bit is all. That's how they work. Some like their own thinner but most will cut with just a little water. It's like pin stripers do with One Shot striping enamels too, a little mineral spirits in there makes all the difference in that case. Someone could say enamels brush right from the bottle and not be wrong, they do indeed. But they brush even better cut a little bit.
When in Rome do as the Romans do !
    July 2019
Posted by Robotism on Sunday, August 4, 2019 2:52 PM
I have more acryllic paint ranges than I care to remember. I tend to stick to Vallejo as it thins well with water and has good coverage overall. Huge range of colours and you can always find what you want between their ranges. I like the lack of bad smells and I feel safer if I get a whiff of them than I do more toxic paints. I'm a mini painter so being good for hand brushing is my biggest priority with everything else coming second to it. If I was recommending someone a paint range Vallejo would be my recommendation. It's very hard to ruin a kit with them and you can use tap water to thin them keeping costs dirt cheap. They come in every colour of the rainbow, aren't terribly difficult to air brush, are great value for money and they don't react with anything you want to put over the top of them.
While I have my preference I realize every tool has it's place and you shouldn't get into internet slap fights over your preference. There's effects only enamels can do, only oils can do and only acrylics can do. The right tool for the job is the tool that gets the job done in a way you like while not harming the kit. There's no reason you can't mix and match different types of paints and it's only handicapping yourself to do so. If your wallet can take the hit (and who doesn't like buying some new paint?) then I'd highly recommend exploring multiple paint ranges and paint types. Enamel washes from MIG and AK have revived enamels from the stuff no one uses as it's outdated and hard to work with into a common as muck weathering technique (I'm talking in my area of modeling, not saying some older folks don't like enamels and haven't stuck with them as other paint technology improved). Oils are now beginning to get mainstream attention in arenas outside of military modeling. Even though my main focus is science fiction and fantasy I realize each branch of the modeling tree does things slightly differently and you always have more to learn and explore. All to often we end up rumour mongering or drawing battle lines which really aren't needed, it's human nature but as someone who used to swear off enamels as being unhealthy to use I've realized I was being a bit of a plonker and added them into my tool box.
