Requesting tips on picking a 2nd airbrush
    October 2019
Posted by phil172 on Sunday, January 26, 2020 3:05 PM
I've had my first airbrush for about 3 years now, and I use it all the time.  It's an Iwata Revolution HP-CR.  I love it.
But I'm starting to think about a new airbrush.  I'd mainly like more control and smaller lines.  By more control I think I mean better ability to control the flow.  Mine is double action with a deep trigger, but it doesn't seem all that refined.
I use mine for a lot, but I feel like I'm at the limit of what I can do when I'm working on 1/72 planes and 1/48 tanks.  I don't really do subjects larger than those.
    March 2013
Posted by patrick206 on Sunday, January 26, 2020 4:53 PM
Phil - Golly, your Iwata is a real premium gem, I can't imagine it can't do what you are wanting to do. You don't mention a needle size, but I believe there are several others that are available for your airbrush, soon I think there will be a few Iwata users to stop by, that will be well acqainted with yours and can give you some good advice as to what to do to make it work well for you.
My fellow FSM members that have your airbrush swear by it, I'll bet you can make it work for you, without going to the expense of buying a second.
Patrick
    October 2019
Posted by phil172 on Sunday, January 26, 2020 5:27 PM
Thanks. It has a .5mm tip. I gathered from reading that swapping to a smaller needle wasn't that easy, but if it is, that would solve half my issue.
    April 2004
Posted by Jon_a_its on Monday, January 27, 2020 3:16 AM
phil172
Don Wheeler Reviews the HP-CR here: with a link on how to convert to 0.3mm setup.
Iwata suggest this is a mid-range airbrush and there is useful info about their range and how to use them  well worth a read.
I have a HP-CS with a 0.5mm and 0.3mm headset. The 0.3mm headset (needle, nozzle and cap) allows you to spray much finer lines, for the price of a basic airbrush, so gives you more options.  I thought it a worthwhile exercise.
East Mids Model Club 32nd Annual Show 2nd April 2023
 http://www.eastmidsmodelclub.co.uk/
Don't feed the CM!
    July 2013
Posted by modelmaker66 on Monday, January 27, 2020 3:38 AM
For detail I use a Badger Krome with the .22 needle and nozzle setup. Great results.
    May 2013
Posted by Greg on Monday, January 27, 2020 10:07 AM
patrick206
That is my opinion too, Phil.
phil172
There's nothing to it, 20 second max once you've done it a couple times. (Just as Jon suggested above)
I retired my 30 yr old Paasche back in '13 in favor of the Iwata HP-CS. I do have both the .5mm and .3mm needle/nozzle combos. Like you (and apparently Patrick and Jon) I love mine.
Several years back, like you (again), I wanted a second airbrush. I had done a lot reading online and I guess I thought a new a/b would offer more control and make me a better airbrusher. I settled on a Harder & Steenbeck Evolution 2 in 1.
I love it. It feels better in my hand than my Iwata, the trigger is arguably a tiny bit smoother, and it tears down without tools. (The Iwata needs the little wrench to snug down the head cap).
Now then, it has not made me a better airbrusher, I've yet to find anything I can do with it that I cannot do with the Iwata, the trigger action may be smoother, but I don't seem to possess the dexterity or skills to make it matter. The adjustable stop for the trigger that I thought would be such a cool and perhaps indespensable feature is useless., at least when spraying acrylics.
For whatever reason, I haven't touched my H&S for a long time, I always grab the Iwata. I have no rational explanation, I'd like to know why myself.
Sorry post is a little long, I had a lot of thoughts on the subject.
    May 2013
Posted by Greg on Monday, January 27, 2020 10:53 AM
I just had another thought, Phil.
If you want a second airbrush and the expense is no big deal to you, by all means do indulge yourself. I like having a second in case I do something really stupid with one of them, which is probably more a "when" than an "if".
Plus, they look cool in the little two airbrush holder thingie on my bench. Creates the illusion that I know what I'm doing and seems to impress guests in my basement workshop. Cool
    November 2018
Posted by oldermodelguy on Monday, January 27, 2020 12:01 PM
I pretty much leave my Badger set up with the .25 nozzle set. I like that nozzle anyway, the spray pattern is very smooth and droplet size smaller than with the .5. I'll leave it at that, except to say I have two other brushes so leaving the Badger mostly set up with the small nozzle isn't an issue.
Posted by Wingman_kz on Monday, January 27, 2020 5:30 PM
I have a CR and BR. I like them. The BR comes with a .3 needle and tip. It does most detail work I need and I like the smaller cup for that type of work. I'll admit to thinking about about switching to the Eclipse series because of the drop in tips instead of the threaded ones in the Revolution series. If I need anything finer than the .3, I have a Badger Sotar with the fine setup. I believe its .2. I got a really good price on it several years ago and it's a nice airbrush. I have the "Super Fine" setup in a 105 Patriot as well. I believe its advertised as .25. Mostly I use the .5 setup in the Patriot for priming though. The drop in tips are easy to clean. They all work just fine. I've been using the Revolutions the most recently but they all get used. Tony
    October 2019
Posted by phil172 on Monday, January 27, 2020 6:38 PM
Thanks everybody.  @Jon: I love Don's website.  But that link seems to be defunct.
I will look into the swapping for a smaller needle for this brush.  And keep studying.
I welcome any additonal thoughts.   Thanks!
Phil
Posted by Wingman_kz on Tuesday, January 28, 2020 3:10 PM
If you plan to change your CR to the BR .3mm setup you have to change the needle seal too. The diameter of the needle shaft is different between the CR and BR. No big deal, it screws in and out, just another part you'll need. I'm not certain but I seem to remember that there is a .3mm needle from another Iwata that can be used instead of the BR that has the same shaft size as the CR so you wouldn't have to change the needle seal. There used to be information on the ARC forums about this but I can't find it now. Its been a few years. Tony
    May 2013
Posted by Greg on Wednesday, January 29, 2020 7:01 PM
Wingman_kz
Oh boy, I misread the OP and thought we were discussing the HP-CS. Good catch, Tony.
The CR is a great brush, I still contend that .5mm is fine, but heed Tony's advice about needle change.
Sorry!
    July 2013
Posted by modelmaker66 on Thursday, January 30, 2020 2:15 AM
You will get tired of switching needle/nozzle/tip sets really fast! Hard to keep track what goes with what. Badger sotar  fine setup is a great detail brush at a attractive price.
    May 2013
Posted by Greg on Thursday, January 30, 2020 8:46 AM
modelmaker66
Hmmmm, those are two really good and absolutely true points, IMO. The second one might sound like no big deal, but MM is right.
Reasons to consider a second a/b indeed. Good input.
    November 2018
Posted by oldermodelguy on Thursday, January 30, 2020 9:39 AM
The Sotar is a nice brush, just to put a price tag on your message MM66, SpayGunner has the Sotar brush with fine needle/nozzle in a plastic case for $100. . Just sayin.
    August 2005
Posted by EdGrune on Thursday, January 30, 2020 10:16 AM
Ken Schlofelt (president of Badger Airbrush) is having his 56th birthday sale.   All Badger airbrushes are $56.00 plus $14.00 S&H.  Go BadgerAirbrush.com    Act now   Sale closes soon
I got a Sotar 20/20 last year for $55 + S&H   See a pattern (?)
Satisfied with the brush    Only complaint was the time it took to receive the order    They were swamped with prders
    May 2013
Posted by Greg on Thursday, January 30, 2020 4:56 PM
EdGrune
eh? I don't see anything about a sale on the badger site.
I'd order a 105 with .7mm needle setup in a heartbeat at $56 + $14 S&H !
    August 2005
Posted by Phil_H on Thursday, January 30, 2020 5:18 PM
Greg
http://www.badgerairbrush.com/H56B_guidelines_rules.asp
    November 2018
Posted by oldermodelguy on Thursday, January 30, 2020 5:45 PM
Greg
EdGrune
If it happens you miss the deal Greg, SprayGunner has the 105 for $75 last I knew.
    May 2013
Posted by Greg on Friday, January 31, 2020 9:58 AM
Phil_H
Greg
Thank you, Phil (and Ed for the original info). I don't guess I'd ever have found that on my own.
    May 2013
Posted by Greg on Friday, January 31, 2020 10:00 AM
oldermodelguy
Thanks, OMG.
    May 2004
Posted by cbaltrin on Friday, January 31, 2020 11:37 AM
Greg
I like your thought process Greg, you're my kind of model builder.
:-P
On the Bench: Too Much
    May 2013
Posted by Greg on Friday, January 31, 2020 11:42 AM
cbaltrin
....and I appreciate your comment, thanks!
    October 2016
Posted by Mrchntmarine on Friday, January 31, 2020 3:54 PM
Greg
EdGrune
So i see 3 105's - Patriot, patriot Arrow and Extreme Patriot , .3 or .5,no .7.    Besides the needle difference, do you know the other differences??
Keep on modeling!
All the best,
William
Posted by Wingman_kz on Friday, January 31, 2020 4:13 PM
Patriot and Patriot Arrow are the same except the Arrow has a smaller cup. Patriot Extreme adds a dark finish, precision air control valve and the. 3mm needle. The Extreme Arrow is the same but again, with a smaller cup. The Precision Air Control Valve is the little knob under the paint cup. It allows you to control the air flow/pressure to a degree at the brush. Tony
PS...Forgot to mention the High Roller trigger on the Extremes. It's a taller trigger than on the standard Patriots.
    May 2013
Posted by Greg on Friday, January 31, 2020 4:40 PM
Mrchntmarine
I don't really know a thing about Badger airbrushes short of thier outstanding reputation on all fronts.
I'm glad to see Tony chimed in to address your question.
I also didn't see anything about a 105 equipped with a .7mm needle/nozzle. I presume I'd have to buy one of the others then buy the .7mm kit separately, which for me sort of defeats the sale price. That is not a complaint, the sale still looks like a very good deal.
    October 2016
Posted by Mrchntmarine on Friday, January 31, 2020 10:34 PM
tks greg and tony.  good to know.  what a sale!
Keep on modeling!
All the best,
William
    May 2013
Posted by Greg on Saturday, February 1, 2020 9:45 AM
Mrchntmarine
what a sale!
It really is. Glad it was pointed out.
I didn't contribute much, but you are most certainly welcome.
