Bish
Tanker-Builder
I have a question;
What in the name of flurry is a wet Palette? I know what a Palette is. I have done oil painting and such and I have a smaller version of the one Bob Ross uses. I use a little one for modeling. Now what is the use and need for a wet palette as well?
I have to offer a minor correction, or clarification, about the "wet" part. I don't know of any wet palettes that use tissue. It'd fall apart. Rather, a wet palette typically contains a sponge of some kind, and a permeable paper that can stand up to being wet.
When I first started working with one, I made my own out of a take-out container, a kitchen sponge, and brown packaging paper as the permeable paper:
Some people use kitchen parchment paper. But most brands are treated with silicone, to make them impermeable-so things don't stick-and you have to prepare the paper, if you want to use it as a palette. The trick I have read about is to boil the paper. Personally, I don't use it, that's too much effort.
I used that palette for a year or two, to get used to working with one, and then I bought myself a commercially-produced palette, from GreenGrass Games.
My homemade palette worked OK, though with repeated use, yes, the sponge would get a little grungey, the plastic wore out and cracked, losing the air-tight quality, and the packaging paper would start to break down, resulting in fibers in my paint.
To clean the sponge, I would just nuke it from time to time. I could keep paint for about a week. I refreshed the palette by pouring a little water in it as it evaporated.
The GreenGrass palette is nice, because it has a small footprint on the bench. Their paper is super-fine. And you can re-use a piece of paper. But I sometimes find myself looking back on my homemade one, because I got so used to how it works.
Also, though I paint figures, I use it on any model work involving water-based acrylics.
It does help working on a subject, to be able to keep a batch of colors fresh from one session to the next.
