Help with my Iwata Eclipse HP-CS
    March 2020
Posted by Zadok Allen on Thursday, March 12, 2020 1:22 PM
So, I have an Iwata Eclipse hp-cs and have noticed a thing when I spray air at higher psi. Since I usually test run with water before I airbrush, I have noticed that it atomizes the water and sprays it out when I spray only air. this happens at higher psi than 20, is this normal. I have a needle set of 3.5.(I bought a new 3.5 Nozzle, but no change) This does not happen when I spray with my 5.0 needle kit. Hope someone knows if this is normal. Regards
    October 2008
Posted by Don Wheeler on Friday, March 13, 2020 6:23 PM
If it sprays before you pull back on the trigger, then the needle isn't sealing against the nozzle opening.  It could be dried paint inside the nozzle.
Don
https://sites.google.com/site/donsairbrushtips/home
A collection of airbrush tips and reviews
Also an Amazon E-book and paperback of tips.
    July 2013
Posted by modelmaker66 on Saturday, March 14, 2020 2:17 AM
Or it could also be that the needle has been pressed to aggresively in thenozzle and has widened the opening to where it doesn't seat right now. Try a thorough cleaning of the nozzle and see how it is. Also make sure the needle is pushed against the nozzle sufficiently but not too hard.
