Tacky paint
    January 2013
Tacky paint
Posted by seastallion53 on Thursday, June 11, 2020 5:58 AM
I airbrushed vallejo model air thinned aluminum on my model 4 days ago and it's still a little tacky.Can anyone tell me why?
    November 2018
Posted by oldermodelguy on Thursday, June 11, 2020 9:51 AM
What did you thin it with ?
    April 2006
Posted by jgeratic on Thursday, June 11, 2020 9:54 AM
Was there a primer or some other paint underneath that was still curing when you applied the aluminum?
Assuming the Vallejo product was sufficiently stirred/shaken, is this the first time using it?  Did you do a heavy spray coat, or work up in thin layers?
How is the humidty, that will extend drying time.
Could be any of these and even combinations there of, or just a bad formulated bottle of paint.
regards,
Jack
    January 2013
Posted by seastallion53 on Thursday, June 11, 2020 10:15 AM
ak thinner
    January 2013
Posted by seastallion53 on Thursday, June 11, 2020 10:18 AM
had no primer and i have a shaker and used it alot in thin layers,could be huminity.i live in northern Cal.
    April 2006
Posted by jgeratic on Thursday, June 11, 2020 10:28 AM
A different brand thinner could be the culprit.
Though both brands advertise the acrylic aspect of their products, there are different types/formulas that don't make them thoroughly compatible.   AK is likely acrylic lacquer (like Tamiya), while Vallejo is water based.
regards,
Jack
    November 2018
Posted by oldermodelguy on Thursday, June 11, 2020 12:00 PM
seastallion53
ak thinner
First, Model Air should be able to be sprayed without thinning, for various reasons we like to thin it but meanwhile it will probably go through your airbrush fine. I propose you do a test shoot onto something plastic, a spoon, spare part or even a spru  from the kit you are painting but something plastic.. . From that compare your dry time. It should be dry to the touch in minutes and handleable the next day.
Most paints should have primer under them, most acrylics really need it though. You will run into adhesion trouble and wear through problems enough, never mind with no primer. Primer really matters with most acrylic paints. Nuff said.
By the way, if it dries fine without thinner I think you know the answer regarding the thinner you used..
    July 2013
Posted by modelmaker66 on Thursday, June 11, 2020 2:42 PM
The high humidity could be the issue. Maybe the layer is thicker than you realize too. Try a go over with a hair dryer from about 8 inches away. That should dry it down.
    January 2013
Posted by seastallion53 on Thursday, June 11, 2020 5:18 PM
Thanks for the ideas,it's always good to tap into this think tank.
