Do you mask and brush paint?
    June 2020
Posted by JimLo on Saturday, July 4, 2020 12:24 AM
8 out of 10 times when I mask , paint seeps through even when I burnish the tape well. Is it because I brush paint which is thicker? When I airbrush the results are better but if I lay down too thick paint it also seeps through. I use Tamiya masking tape.
    August 2014
Posted by goldhammer on Saturday, July 4, 2020 12:30 AM
I usually only brush small items and pick out details.
But a thicker coat will stay wetter longer, and could work under the edge of a thin tape like Tamiya.  You could try to brush a thin coat of clear on the edge first to seal it.
    April 2009
Posted by Cadet Chuck on Saturday, July 4, 2020 6:53 AM
Right!  After burnishing, brushing a thin coat of clear on the edge of the tape will seal it.  Let it dry completely before overcoating your color.
    October 2016
Posted by Mrchntmarine on Saturday, July 4, 2020 9:14 AM
Use to have that problem. There was a tip on the site in which someone suggested to cut a thin strip off the edge of the tape before applying. I keep all my tapes just laying on their sides and I think it helps to get a thin smooth edge back.
Keep on modeling!
All the best,
William
