Chris,
The abbreviation, "NPT" stands for National Pipe Thread and it is the standard for pipe fittings in the U.S as you probably already know.
That fitting you are showing is a 1/4" NPT I believe as that is pretty much the standard size used on Badger, Paasche, and other air hoses where they connect to the compressor. Although they are called, "1/4" they are much larger than that as the NPT system is odd as are most thread standards for pipe threads. Who thinks these things up anyhow?
“Wisdom is the right use of knowledge. To know is not
to be wise. Many men know a great deal, and are all the greater fools
for it. There is no fool so great a fool as a knowing fool. But to know
how to use knowledge is to have wisdom. " Charles Spurgeon
