MusicCity, I found a gallon jug of Simple Green in a local tractor store. It is a concentrate; and far more than I need for $13.00. Is this the product you use? If so, how do you dilute it?Thanks for your feedback!
On the Bench:
Revell 1/96 USS Constitution - rigging
Revell 1/48 B-1B Lancer Prep and research
Trumpeter 1/350 USS Hornet CV-8 Prep and research
Shipwreck MusicCity, I found a gallon jug of Simple Green in a local tractor store. It is a concentrate; and far more than I need for $13.00. Is this the product you use? If so, how do you dilute it?Thanks for your feedback!
The bottle will tell you on it how much of it to mix with water in another container.
If that is more than you need you should be able to find it at Walmart, Pep Boys or a supermarket.
I see it everywhere here.
I would go to Home Depot or Lowes before going to Walmart. Last few times I have looked for it at Walmart they didn't have it. They instead had this cheap green clearer that is nothing like Simple Green. The Walmart stuff is just a ploy to get people that are wanting to be eco. The same goes for most grocery stores I have see around here. I am in Texas so location might be part of it. Home Depot is where I get mine.
SImple Green is some good stuff. If you buy the spray bottle there is no need to delute it. If you use acrylics and need to strip the paint let the part or parts soak in some Simple Green and the paint will come right off after a few minutes.
To clean my airbrush I use a mix of 1/3 Simple green 1/3 Windex 1/3 Distilled water.
Works great (I use Acryics BTW)
