Tamiya Spray Can Olive Drab Questioin
    September 2020
Posted by VintageRPM on Monday, April 19, 2021 8:59 AM
What is the difference between Tamiya TS-5 and TS-28 spray paints? Both are Olive Drab. Is one gloss and one flat?
    April 2020
Posted by Eaglecash867 on Monday, April 19, 2021 11:53 AM
They're slightly different colors, with TS-28 being called Olive Drab 2.  There were two Olive Drab colors for US equipment, and I think that's why they have the two slightly different colors.
Here's a Tamiya color chart.
https://www.tamiyausa.com/media/post_content/tamiya-ts-paint-chips-be5c.jpg
"You can have my illegal fireworks when you pry them from my cold, dead fingers...which are...over there somewhere."
    September 2020
Posted by VintageRPM on Monday, April 19, 2021 12:08 PM
I see on the chart that there is even a third Olive Green, TS-70, which is used by the JGSDF. But, to get back to the second part of my question, are they flat or gloss? I'm actually looking for gloss for a specific project. (Trying to avoid the extra step of gloss coating flat paint.) Mike
    January 2020
Posted by wpwar11 on Monday, April 19, 2021 12:34 PM
I was just reading about this yesterday.  So it seems some Navy planes during WW2 had two different colors for olive drab.  One was used prior to 1943 and the other shade after. So yes, as Eagle mentioned they are different colors.  At least this was the case with The P47 D.  If I'm wrong please someone correct me.  I don't research subjects as much as I should.
    April 2020
Posted by Eaglecash867 on Monday, April 19, 2021 12:51 PM
VintageRPM
Since they're for military subjects, my guess would be that they're flat paints.  Don't know that for sure though.
    April 2013
Posted by KnightTemplar5150 on Monday, April 19, 2021 5:16 PM
I don't know if I would describe the finish as being completely "flat" with the TS-5 version of OD. It isn't exactly "gloss", either. The synthetic lacquer levels so well that it gives what my local hardware store refers to as a "satin egg-shell" finish. In the right light, it looks a bit like a semi-gloss because it cures so smoothly.
