oldermodelguy
Paasche H's are just about indestructable aren't they ? I use mine more than my Badger these days since shooting quite a lot of acrylics and enamels and after the loss of MM Metalizers. I bought it as a back up about 7-8 years ago while I upgraded my Badger 200 to the newer air caps and such.. The 200 was in need of a really good clean up after 40 years of use . It's always good to have a back up imo. The Paasche H is a work horse, pretty inexpensive too. And it has hefty parts, large orifices etc. These days I keep the #3 tip on that and the .25 in the 200. My hands slip now and then as I'm aging, I've dropped that H on the floor twice now and it just keeps going. Not that I'm advocating doing such a thing mind you. If nothing else though, a guy could get an H and once everything is squared away with their other air brush or brushes, use the H for primers, heavy clears or whatever.
I use mine for everything now...had the same one for 35 years so far. I usually use my #1 air caps and needles with it, since I like a nice, thin coat of paint. I have 2 sets of the #1s, and 2 sets of the #3s, along with 2 color cups. When I get done with one color, I just dump the needle, cap, and cup into my relish jar of MEK in the ultrasonic cleaner and then put the second needle/cap/cup set on the airbrush to shoot the next color. That set also goes in the jar and everything gets a thorough cleaning for about 30 minutes while I work on other stuff. I bought an Iwata HP-CS last year, thinking I would really like it...its still practically brand new because it was a PITA using it, and I have never liked the concept of shooting a bunch of solvent into the air to flush it. After using the H for so many years, I haven't run into a situation yet where I wished I had a different airbrush...it can do pretty much anything I need it to. Working on the bare metal tail surfaces of my Tamiya F-4B project with it this weekend, and getting amazing results so far. Its definitely my workhorse.
