QUOTE: Originally posted by saltydog
but mike, i have to call your hand on this one thing though. how do you know its not worth the extra money if you've never held or felt or sprayed paint through an iwata hp-c? it was worth the money to me and if i had it to do over again, i'd spend it again. you are basing your opinion on information you've collected from different people instead of hands on experience. i dont think you are qualified to make that statement in my opinion. and please dont take that in the wrong way, because i'm definetly not trying to start anything here, i know you are a qualified and bonefied airbrush user for sure, but if you havent actually tried the airbrush in question, how can you truelly form an opinion about it? thats all. |
Chris,
That is a valid point and it is true that I have not used an HP-C to compare them, but I am giving an opinion based on what the experts in the airbrushing business would recommend. If you were to ask some of the top airbrush experts in the country which Iwata they would recommend for a modeling airbrush they would say the Eclipse series.
You yourself said you bought a .4mm needle and tip for your HP-C did you not?
The Eclipse CS has a .35mm tip and needle which should be capable of possibly an even finer line, so why is the extra money necessary for the HP-C?
If you like the feel of the HP-C better then that's fine, but why spend an extra $30 on an airbrush that offers no real advantage especially to an inexperienced airbrush user?
If you want to carry this type of thinking to it's logical conclusion then why not recommend the Iwata Micron to everyone? It is capable of the finest lines of any airbrush except the Sotar and the Paasche AB, so buy it and you can brag that you have the best, even though I guarantee you won't have any better results with it than you will with your HP-CS or Omni 5000.
![](http://img.photobucket.com/albums/v207/MikeV/225px-MALS-26.png)
“Wisdom is the right use of knowledge. To know is not
to be wise. Many men know a great deal, and are all the greater fools
for it. There is no fool so great a fool as a knowing fool. But to know
how to use knowledge is to have wisdom. " Charles Spurgeon
