Paint issue
    April 2023
Paint issue
Posted by John3M on Wednesday, June 21, 2023 10:38 AM
Getting back to modeling after many years. I use airbrushing primarily. The question i have is I recently purchased a simple car model 57 Chevrolet Bel Air and cleaned it up to paint the body. I wash parts first. But the problem i seem to have is after putting primer on the car and letting it sit for a week while on a fishing trip. I came home to work on the car. I wanted to paint the car an opaque red over white primer. which I did. now the red paint after sitting for a day or so did not seem to set up as expected. both primer and red were acrylic water base. but the red is not set or hardened. I litely sand the first coat to prepare for the next coat. The paint did not seem quite ready, which i can't figure. It's like it's not hardening. It's not sticky but it's not what i call done. i included pictures of the paint bottles but they wont upload
    November 2018
Posted by oldermodelguy on Wednesday, June 21, 2023 4:32 PM
Just name the paint brands used.
    July 2004
Posted by stikpusher on Wednesday, June 21, 2023 4:50 PM
Yes, what brand of acrylic paint did you use? And what, if anything did you use to thin the paint for airbrushing?
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    April 2023
Posted by John3M on Wednesday, June 21, 2023 4:54 PM
Us art supply opaque red acrylic
vallejo mcha primer acrylic
    July 2004
Posted by stikpusher on Wednesday, June 21, 2023 6:14 PM
I've never used the US Art Supply paint, so I can't comment there. But the Vallejo primer, if it's anything like Vallejo Model Air, may have a "rubbery" feel once dry, for lack of a better term.
       - Plankton
LSM
    April 2023
Posted by John3M on Wednesday, June 21, 2023 9:40 PM
Rubbery was what the red paint felt like
    November 2008
Posted by plasticjunkie on Thursday, June 22, 2023 8:44 AM
I have never heard of this brand. I googled paint reviews and read the same issues you are having were noted on plastics.  That paint may not be suited to go on plastic but on canvass or clothing. I suggest using paints designed for our hobby as in  plastic models. As for Vallejo, not a fan of it and would use a better primer that has good adhesion.
 GIFMaker.org_jy_Ayj_O
    April 2023
Posted by John3M on Thursday, June 22, 2023 9:43 AM
What paint do you use?
    September 2006
Posted by the Baron on Thursday, June 22, 2023 10:38 AM
I did a search on US Art Supply, too, and it sounds like it's really more of an arts & crafts paint brand.
I use some craft store paints, among other paints, like Americana, Folk Art, and Apple Barrel.  They're all fine for hand-brushing, especially on figures, and for weathering. And they can be airbrushed.
But since they're formulated more for arts & crafts use than for scale modeling, I don't recommend them for airbrushing.  I found that the pigments are a little more granular than in modeling paint brands. So the finished surfaces can have more of a texture than say Tamiya, or the now-defunct Model Master, MRP, Mr Hobby, and so on.
Are you limited to using water-soluable acrylics, for example, because of the fumes lacquers or enamels give off?  Or could you try those? Many car modelers do.
    April 2020
Posted by Eaglecash867 on Thursday, June 22, 2023 10:39 AM
I'm not a fan of Vallejo or any water-based acrylic for airbrushing either.  For a primer, I use decanted Tamiya Surface Primer, thinned with MEK for extra bite on the plastic.  Gunze has their Mr. Surfacer primer that is already in bottles, and its pretty much the same stuff as far as I can tell.  I used to use Mr. Surfacer 1000, also thinned with MEK, and that was an excellent airbrushed primer.  For painting a car body, I would recommend an enamel paint like MCW or Model Master (you can still find Model Master enamels, but they don't make them anymore, so they're usually pretty costly).  Enamels do take a while to fully cure (about a week for a gloss paintjob) and they are a little fragile, but they're far more durable than most acrylics, and lacquers are great for durability and drying time, but its much more difficult to get a good gloss with those because they dry so quickly.
"You can have my illegal fireworks when you pry them from my cold, dead fingers...which are...over there somewhere."
    April 2023
Posted by John3M on Thursday, June 22, 2023 11:07 AM
Not limited to acrylic but i am both by fumes
i did not know you could use mek with acrylic paint. However i have a paint hood with extraction to outside.
    April 2020
Posted by Eaglecash867 on Thursday, June 22, 2023 11:30 AM
John3M
i did know you could use mek with acrylic paint. However i have a paint hood with extraction to outside.
MEK and acrylic paint aren't compatible, so don't mix those together, it'll gum up your airbrush.  The primers I thin with MEK are both lacquers.
The good thing about both MEK and lacquer-based paints and primers is that, although they all are really smelly, they dry so quickly that the smell doesn't linger like it does with enamels.  You can also keep the fumes to a minimum with your airbrushing technique.  Unlike a lot of guys I see making videos on YouTube, I've never seen the need for using my airbrush like a firehose and shooting clouds of paint mist.  Nearly all of the paint I'm shooting is going on the model and not into the air.
    November 2008
Posted by plasticjunkie on Thursday, June 22, 2023 12:39 PM
Eaglecash867
Ditto
    November 2008
Posted by plasticjunkie on Thursday, June 22, 2023 12:56 PM
John3M
I use enamels and lacquers like Mr. Color, Tamiya, Testors, Alclad. As for primers I use Mr. Surfacer, and Tamiya both have superior bonding qualities over acrylics.
    April 2023
Posted by John3M on Thursday, June 22, 2023 3:53 PM
My editor messed up i thought you said it could mix with mek and i ment to say i did not know it could mix
    July 2023
Posted by Lightning Pilot on Thursday, July 20, 2023 1:43 PM
I am a fan of Vallejo primers. Used properly, on a clean surface they work quite well, especially under Vallejo paints.
Paint and solvent compatibility is always an issue. Unless you really know your paint chemistry, mixing different types is an experiment waiting to go wrong. It's not worth ruining an expensive kit or wasting expensive paint.
I was once a coatings chemist, and I don't experiment on kits. My suggestion is to strip the paint from the model, and only use compatible paints intended for scale modeling.
    September 2006
Posted by the Baron on Friday, July 21, 2023 11:14 AM
Lightning Pilot
...and only use compatible paints intended for scale modeling.
And if someone wants to experiment, use a "test mule"-an old kit, other scraps of styrene, like lawn signs, milk jugs, plastic spoons, etc, before shooting it on a model.
    November 2018
Posted by oldermodelguy on Friday, July 21, 2023 11:36 AM
I have no issue with Vallejo paints. The primer in my book is just OK, but Stynylrez is a big notch up and a very similar type of primer ( acrylic/poly). Both apply nice but Vallejo really is a next day cure type primer, where Stynylrez is ready to go in 30 minutes to an hour. Vallejo is non sanding, Stynylrez sands or scuffs very well. Stynylrez will handle a full blue painters tape pull test ( I've conducted this test myself). Stynylrez will accept all acrylics, water borne or alcohol, along with enamels and mild lacquers. If hot lacquer is someones thing then stick with the solvent based lacquer primers . Stynylrez is also a primer/sealer. Not sure if Vallejo primer ticks that box or not.
I've been using Stynylrez in the fashion I mention above for 7-8 years now. The only stipulation is if it's shelved for long periods of time then it needs a good power mixing with something like the Badger battery operated hand held mixer. You will never get it all back together by shaking or with a stick. And never let it freeze, if it freezes it's over with. Just sayin.
    July 2023
Posted by Lightning Pilot on Friday, July 21, 2023 1:30 PM
I've discovered that very light sanding (≥800 grit), or even polishing with a polishing stick can be used to remove minor defects in Vallejo primer coats.
Somewhere on the Vallejo website I read a recommendation for buffing the primer coat with blotter paper or equivalent. Haven't tried that, yet.
    November 2018
Posted by oldermodelguy on Friday, July 21, 2023 2:52 PM
Lightning Pilot
I used to buff up Stynylrez with 000 steel wool ( it actually made a sheen on it), that may work on the Vallejo primer well, though I haven't tried it. I should, then I can add it to my 8 year long list of tests of various acrylic paints lol. I have nothing against Vallejo primer personally, I just like Stynylrez better. I know some folks just about hate the stuff but I have no idea if they follow Vallejo's suggested 24 hour cure time etc.
Anyway, I stopped the steel wool idea on Stynylrez for a couple of reasons. Most of the time it needs nothing. When it needs a scuff micro pads work fine at around 1000- 1500 or so. But I wanted a bit of tooth to the scuff, not a polishing. But with stynylrez you can sand it down to feather it off if you wanted to.
    December 2022
Posted by CFster on Wednesday, July 26, 2023 3:09 AM
Surely you're not recommending people spray lacquers without a respirator and proper ventilation, right? And you realize it's not about the smell, it's about the airborne VOCs.
    November 2018
Posted by oldermodelguy on Wednesday, July 26, 2023 4:27 AM
CFster
I don't think anyone in the thread has suggested not using a mask in general, be that for spraying solvent paints or water borne acrylics. Most here use them anyway.
    April 2020
Posted by Eaglecash867 on Wednesday, July 26, 2023 7:04 AM
CFster
Nobody said that here, and it would help a great deal if you would use the quote feature so people can determine who it is that you're addressing your reply to. Yeah
    September 2006
Posted by the Baron on Wednesday, July 26, 2023 9:20 AM
Yes
    April 2023
Posted by ctruss53 on Thursday, July 27, 2023 3:29 PM
I kind of skimmed the replies, but I wanted to touch on one term I saw the OP use.
Rubbery
If you are using an acrylic paint that is designed for clothing, or lexan, or any other flexible surface, you are buying a paint that will cure "rubbery" because it needs to cure flexible in those applications.  I can't say for sure your paint is like this, but when I hear "craft store acrylic" and "cured rubbery" I have a feeling this might be what is going on.
Strip the paint and start over.  For acrylic paints I use LA's Totally Awesome. That stuff works great and will strip acrylic paint in minutes.
After you strip the paint wash the parts in soapy water to remove any leftover Totally Awesome.
Then I recommend a paint that might be better suited to the application.  If you want to stick with low odor, try Tamiya X or XF line of acrylic paints. They have some solvent in them so there is a little odor, but they can be used inside.
To thin the X or XF paints, you can use Tamiya acrylic thinner. If you can use something with odor, like you have a way to ventillate, then get some Mr Leveling Thinner from Mr Hobby. Tamiya paints love that stuff.
I will get bad remarks about this, but you can thin X and XF Tamiya paints with water. People will disagree, but it works. This will keep the odors down if you don't have ventillation.
Another option for low odor acrylic paints is the Createx line. They are available in craft stores, art supply stores, and Hobby Lobby. They are acrylic and low odor and have a nice gloss clear to put over your paint.
Insert wise quote here.
-Chad
    April 2023
Posted by John3M on Thursday, July 27, 2023 4:07 PM
ctruss53
Rubbery
If you are using an acrylic paint that is designed for clothing, or lexan, or any other flexible surface, you are buying a paint that i will cure "rubbery" because it needs to cure flexible in those applications.  I can't say for sure your paint is like this, but when I hear "craft store acrylic" and "cured rubbery" I have a feeling this might be what is going on.
 I appreciate the thoughtful reply. Gone are the days when we had only one source of paint in the little carboard box with the variety of enamels. i know they are still available but im a little more choosy now. Thinning for airbrushing is something i am tackling now im looking for a pdf i can print as a handy source for hobby paint and thinning. I am leaning toward Craftex and Model Master since i have quit a large collection of MM from my other hobbie.
    November 2018
Posted by oldermodelguy on Thursday, July 27, 2023 5:06 PM
ctruss53
l
Chad, about Createx ( and you may have seen me post on this before and you can check with Createx instructional videos to confirm). You may or may not realize that it too was designed for fabrics, that was the original intent for the actual Createx opaques and transparent colors. To counter this and so the paint is adapted to hard surface painting they developed Createx 4030 to put in the paints ( called 4030 Intercoat). This converts the Createx paints to a poly acrylic and gets the dried finish away from that tackiness some modelers have complainted about. It may even work well in the OP's paints, as I use it in many acrylic paints besides Createx ( which I do use Createx as well). It's good in many craft paints as well to improve flow and adhesion. Good stuff ! I think the only acrylic I don't use it in is Tamiya.
I'm mixing up Createx red, blue and yellow now ( recently) to make maroon for a 34 Ford pickup build).  But anyway, my point here is that if the OP goes straight up Createx he could be in the same boat he is already in with "rubbery" if no 4030 is used in the blend.
I don't find Tamiya acrylics to be offensive on odor at all, whether thinned with even lacquer thinner. Ya its a bit more odor than pure water borne paints but not very strong and short lived. It may be different in tight confines but it's nothing like lacquer or even enamel.
    September 2006
Posted by the Baron on Friday, July 28, 2023 9:44 AM
ctruss53
...I will get bad remarks about this, but you can thin X and XF Tamiya paints with water. People will disagree, but it works...
I hope my reply doesn't count as a bad remark, but I must disagree with you on using water to thin Tamiya's acrylics.  Or perhaps to note that that is not consistently so.  I tried using water to thin them, early on, because Tamiya's proprietary thinner is relatively expensive.  But the paint had a tendency to clump, or for one coat to lift off the previous coat.  So I decided to toss aside my natural Dutchiness and buy Tamiya's X-20A thinner.  Immediately I got me consistently good results.
Of course, anyone can try what he wants.  But it's good to bear that caution in mind.
    April 2020
Posted by Eaglecash867 on Friday, July 28, 2023 10:17 AM
the Baron
I hope my reply doesn't count as a bad remark, but I must disagree with you on using water to thin Tamiya's acrylics.  Or perhaps to note that that is not consistently so.  I tried using water to thin them, early on, because Tamiya's proprietary thinner is relatively expensive.  But the paint had a tendency to clump, or for one coat to lift off the previous coat.  So I decided to toss aside my natural Dutchiness and buy Tamiya's X-20A thinner.  Immediately I got me consistently good results.  Of course, anyone can try what he wants.  But it's good to bear that caution in mind.
I've never had much luck with water in Tamiya acrylics either.  What did end up working for me is 99% isopropyl alcohol, so I buy that stuff by the gallon at our aviation supply store at the airport I'm based at.  Makes a great paint stripper too, and alcohol is about the most harmless, styrene-friendly chemical you can use for that purpose.
    April 2023
Posted by ctruss53 on Friday, July 28, 2023 10:38 AM
the Baron
ctruss53
It didn't work for you, thats fine.  I use water and it works totally fine. I mix about 4 parts paint to 3 parts water. And it sprays out fine.
-Chad
