NO gloss finish!
    April 2016
NO gloss finish!
Posted by GlennH on Thursday, April 4, 2024 3:08 PM
I don't know what's going on here. I recently wrapped up a model and began prepping it for decals. It was painted with rattle can flat OD enamel. I went over it with Rustoleum clear high gloss enamel and even after three coats very little of the model showed the effects. It was almost as if I had not done anything. Naturally the only parts of the model that showed any signs of high gloss were not near the upcoming decal locations.
What can cause this problem? I am spraying from about 8 inches away and the paint is obviously wet and glossy at first.
A number Army Viet Nam scans from hundreds yet to be done:
https://www.flickr.com/photos/southwestdreams/albums/72157621855914355
Have had the great fortune to be on every side of the howitzers.
fox
    January 2007
Posted by fox on Thursday, April 4, 2024 9:16 PM
I can only guess that it could be 1 of 3 problems:
1 - The paint was not mixed well enough. 2 - The paint or painting area was not warm enough or humidity too high. 3 - It was a bad batch of paint. Did you test the paint on a test piece? These are problems that I have experienced over my years of painting.
Hope that this helps.
Stay safe.
Jim Captain
 Main WIP:
