Martyhh
I was wondering what the pluses and minuses are for using oil paints. Can one paint an entire model with oil paints, and are they amenable to brush painting?
Assuming that by 'oil paints' you mean artists-type oils, here's my
In my opinion the chief virtue of oils are their blendability. You can get very subtle shadings and gradations of colors with relative ease (and a minimum of experience), and because they don't 'flow' like liquid paints do, they're easier for the novice to control.
Those features lend themselves particularly well to painting things like figures. I have done many figures, from 90mm down to 1/72, entirely in oils -- where things like skin tones, shading, and tiny details (like eyes, eyebrows and facial topography) are pretty easy to master using small-tip brushes. For clothing and uniforms, both textures, shading and precise details like insignia are often easier to render using oils, and the intense colors available make such details stand out to the observer.
I have also used oils a lot for weathering, where their blendability and ease of techniques like dry-brushing are tailor-made. You can apply oils and wipe them away to leave what is essentially a wash -- or brush them down so thinly as to be a transparent glaze. Both of those can of course be done with conventional hobby paints, but those require thinning: and when you start adding solvents to paints, weird things can happen. With oils, they are basically pre-thinned, which leaves one less 'x factor' to deal with.
Finally (I know it seems like this will never end
), oils lend themselves well to small details of any sort on models: say, tools on armor, or engines, landing gear and tires on aircraft. What they do less well is to lay down large areas of even color of the type typically seen on 'paint schemes' for vehicles, planes and ships. Not impossible, by any means, but those effects are IMHO more easily accomplished with more traditional hobby paints and methods.
Main drawback of oils, of course, is that they tend to be slow-drying; though in the minute quantities used for most weathering and detail work, that's not really that much of a problem, broadly comparable to enamels and such.
End of rant. ![Big Smile](http://cs.finescale.com/emoticons/emotion-2.gif)
