floquil primer
    July 2003
floquil primer
Posted by saltydog on Saturday, May 1, 2004 9:58 AM
is it ok to wet sand flogquil primer?
Chris The Origins of Murphy's Law: "In the begginning there was nothing, and it exploded."!!! _________ chris
Posted by MikeV on Saturday, May 1, 2004 10:35 AM
Sure. I did with mine on a couple of spots.
That is the Railroad line of Floquil primer right?
    July 2003
Posted by saltydog on Saturday, May 1, 2004 11:01 AM
correct.
Posted by MikeV on Saturday, May 1, 2004 12:29 PM
Go for it then Chris. Wink [;)]
Posted by rjkplasticmod on Saturday, May 1, 2004 12:42 PM
No problem wet sanding the Floquil grey primer. Just be sure it has cured for about 48 hours. If you do it too soon you may see little balls of paint rubbing off. Speaking from experience, sadly enough.
Posted by MikeV on Saturday, May 1, 2004 12:51 PM
Good advice Rick.
I always wait 48 hours before applying paint on top of another coat of paint or sanding.
