Future Application Question
Posted by Anonymous on Tuesday, May 11, 2004 1:22 PM
Has anyone applied Future over metal parts? Diecast parts?
i have a old figure/toy that has alot of metal parts. and i wish to clearcote it with Future so the parts won't oxidate. but i don't know if i have the right idea.
Does anyone know if Future will damage metal surfaces?
with it rust in time?
and does anyone have any tips on airbrushing this stuff? i had no luck with it so i have to hand brush everything. and for large surfaces, it because very annoying to handle at times.
When airbrush it, Future comes out too fast and too thick. and all i see are bumps and bubble like surface. i have used an 8-10 psi.
Could it be because the tip of my airbrush needles is a little bent?
    July 2003
Posted by saltydog on Tuesday, May 11, 2004 6:26 PM
lonerbboy, you need to crank the psi up to around 12 to 18 psi and try it again unless you're thinning the stew out of the future. i wouldn't think it would cause any rust on metal but it just my opinion. you have to dust future on from about 2 inches from the subject with light coats and build it up with about 4 or 5 coats. the first 3 coats arent gonna look that glossy but the 4 and 5 start looking level and glossy. later.
Chris The Origins of Murphy's Law: "In the begginning there was nothing, and it exploded."!!! _________ chris
Posted by Anonymous on Tuesday, May 11, 2004 9:53 PM
12-18? i spray future at 45. oh well.
Posted by rjkplasticmod on Tuesday, May 11, 2004 9:58 PM
Future at 45psi ? Do you stand about 3 feet away when you spray ? Sounds like a Silly Post to me.
