nose painting
nose painting
Posted by Anonymous on Tuesday, June 8, 2004 9:38 AM
What is everyone doing to mask the noses of aircraft to get a good straight line. ie: F-18?
Thanks Greg
Posted by wayne baker on Tuesday, June 8, 2004 11:07 AM
Try a circle template from any of the office supply stores. Find a circle that goes back as far as you want, mask the other circles in the template and spray. It works on tires, and anything else that is round and you can lay the template on. And if no one has said it, welcome to the forum.
 I may get so drunk, I have to crawl home. But dammit, I'll crawl like a Marine.
    January 2004
Posted by knight667 on Tuesday, June 8, 2004 1:55 PM
That's gonna come in handy! Big Smile [:D]
John "The only easy day was yesterday." - US Navy SEALs "Improvise. Adapt. Overcome." - US Marine Corp. "I live each day/Like it's my last/...I never look back" - from "I'm A Rocker" by Judas Priest
Posted by Anonymous on Wednesday, June 9, 2004 9:24 AM
Thanks for your ideas. I have been using the plastic circle template, but find I can't get the paint from sneaking under the template.
Thanks for your welcome as well.
Greg
Posted by wayne baker on Wednesday, June 9, 2004 2:25 PM
Are you spraying? If so, try it at an angle to the template, in light coats. Put a piece of masking tape on the back side of the template, cut slightly smaller than the hole you are using. It could form a seal against the model. Cut a piece of masking tape on a diagonal, to wrap around the part. The daigonal makes it easier to lay down straight, on a curve.
