Color for aircraft tires
Posted by MikeV on Friday, July 16, 2004 6:11 PM
Have you guys found any color or color mixture that looks right for the rubber on aircraft tires? I painted mine MM Acryl Flat Black and they just don't look right in that color. I do have an older bottle of Testors "Rubber" color but I don't remember if that looks right or not.
Thanks
Posted by Anonymous on Friday, July 16, 2004 6:28 PM
Mike, that Testor's "Rubber" colour you have looks spot on I reckon.
Cheers...Snowy
    July 2003
Posted by saltydog on Friday, July 16, 2004 6:41 PM
i paint mine flat black and then do alot of dry brushing with grays and dark umber. i works out fairly close. i've seen the color "rubber" but i've never used it. later.
Chris The Origins of Murphy's Law: "In the begginning there was nothing, and it exploded."!!! _________ chris
Posted by MikeV on Friday, July 16, 2004 6:41 PM
Snowy,
I just tried it and now the tire looks like a Tootsie Roll. Laugh [(-D]
It is too brown for rubber.
Posted by Anonymous on Friday, July 16, 2004 7:20 PM
Mike, I just used Testors Rubber on some True Details P47 tyres and they look great but I should have told you there was a few more steps I did. After painting them I hit them with Future, after that cured, ran a Burnt Umber oil wash into the tread pattern. After that I hit them with a flat coat, then, as Salty points out some careful dry brushing with some lighter grey enamels to pop out the tread highlights and sidewalls. Fairly involved, but the result is worth the effort and your tyres will look very realistic. I don't think you will ever get that result straight out of a bottle. Hope this helps you a little. By the way Mike, if your kit parts are starting to look like food, you know it's time to take a break and eat. Smile,Wink, & Grin [swg]
Cheers....Snowy
    May 2003
Posted by qmiester on Friday, July 16, 2004 7:49 PM
Mike,
For years the commonly used paint for used tires was Testors Hotrod Primer - It's darker than Panzer Grey but lighter than flat black. Unfortunatly it was discontinued about 15 years ago (came across 3 bottles of it in the Misc. paints box in an out of the way HS in a small town in western Kansas a couple of years ago - all were usable so I grabbed them). You might try to add white to your black until it is just a little lighter than the black. And I agree with you, the current Testors Rubber is much too brown.
Quincy
Posted by Anonymous on Friday, July 16, 2004 8:30 PM
I use testors rubber followed by a wash of black and a light dry brushing.
John
Posted by Anonymous on Friday, July 16, 2004 8:51 PM
I use Color of Eagles (also called Aircraft Colors) Tire Black. To me, it really looks the part. It's one of the only acrylic paints I use. You can see it on my Avenger below.
Hope this helps.
Posted by rjkplasticmod on Friday, July 16, 2004 9:03 PM
For more modern AC, like your F-15, Floquil " Weathered Black" is pretty good out of the bottle, but like others have said, some washes & dry brushing won't hurt. The Testors "Rubber" is pretty good for WWI AC but nothing later.
Posted by Anonymous on Friday, July 16, 2004 9:16 PM
Gunze Samgyo makes a tire black also that works good, then dry brush with grey on treads.
Posted by MikeV on Friday, July 16, 2004 10:40 PM
Pix,
Who makes "Aircraft Colors" paints? I don't think I have seen them in stores.
Rick,
Thanks for the heads up about Floquil weathered black as it also looks pretty good from what I can tell from Testors web site.
Thanks everyone for all of the good suggestions.
Posted by Anonymous on Friday, July 16, 2004 11:08 PM
Mike - I oder mine from Eagle Strike Productions:
http://www.eaglestrikeproductions.com/
Click "Aircraft Colors" logo. it is listed under "Basic Colors." They don't need mixing, and two coats of their RLM 04 Yellow over white covers VERY well. They're great paints, for acrylics (I prefer enamels).
Posted by Anonymous on Friday, July 16, 2004 11:39 PM
I airbrushed flar black with a drop or two of flat white.
    March 2004
Posted by Mark Joyce on Friday, July 16, 2004 11:58 PM
I still have a partial bottle of Aeromaster's Tire Black that I bought years ago, and I'm quite satisfied with the color. After painting the tire, I drybrush either brown or grey, depending on what type of surface the aircraft flew from (dirt or otherwise).
Mike, I tried using Testor's Rubber once before and like you didn't like the results--too brown. I had never associated the color with a Tootsie Roll, but that's a pretty accurate comparison!Laugh [(-D]
Mark
Ignorance is bliss
Posted by Anonymous on Saturday, July 17, 2004 12:18 AM
I use Polly scale's SQ. black rlm 66. Perfect on tires
Posted by darson on Saturday, July 17, 2004 12:25 AM
Mike,
I have been using Tamiya's Nato Black (XF-69) for a quite a while now and it makes a ver realistic (IMHO) rubber color for any sort of tires. Give it a try.
Cheers
Darren
Posted by Anonymous on Saturday, July 17, 2004 2:51 AM
Mike.......
Aeromaster (enamals & acrylics) did a "Tire Black" which i thought was quite accurate......
it's kinda like a satin black but, with a little grey in it......over here i've found a dark grey------>Xtracrylix (FS16081).....(wishes it was FS36081) but, it'll do nicely once toned down.......
works good.....lasts a long time.....
    July 2003
Posted by KJ200 on Saturday, July 17, 2004 4:30 AM
Mike, like Woodbeck, I use RLM66, followed up with a dark wash, and dry brushing. Find this works really well on treaded tyres, as the RM66 is not so dark as to hide the detail accentuated by the wash.
Karl
Posted by Anonymous on Saturday, July 17, 2004 6:03 AM
Good tip with the NATO Black darson I'll get some and try it, the Tamiya stuff is a bit easier to clean up, not to mention that now these guys have me checking my tyres over and over to see if they're too brown. Blindfold [X-)]. There's nothin' strikes fear into the enemy's heart like a fully loaded P47 on Tootsie rolls thundering down the runway. Laugh [(-D]
Cheers...Snowy
Posted by Jim Barton on Saturday, July 17, 2004 12:34 PM
QUOTE: Originally posted by MikeV
Snowy,
Well, at least it's better than looking like a Lifesaver.Big Smile [:D]
The last time I had to paint tires was on the MiG-21 that I built a few years back and I just simply mixed a droplet of flat white into a small amount of flat black dispensed in one of those little plastic cups you sometimes get with take-out food (that hold salsa or parmesan cheese for example).
"Whaddya mean 'Who's flying the plane?!' Nobody's flying the plane!"
Posted by Anonymous on Saturday, July 17, 2004 1:27 PM
See, me and KJ are on the same wavelength....time for the rest of you to join us!!!!Wink [;)]Alien [alien]Alien [alien]
Posted by rjkplasticmod on Saturday, July 17, 2004 2:38 PM
Thanks Mike, try the Floquil, I think you'll like it. "Aircraft Colors" is a new line of acrylics designed for airbrushing, manufactured by Vallejo. I use their regular line extensively for brush painting, but haven't tried the new paints. From what I've read they are high Quality.
Regards, Rick
    July 2003
Posted by KJ200 on Saturday, July 17, 2004 4:39 PM
Woodbeck, it's not called schwartzegrau for nothing is it?
You'd have though someone apart from us would have spotted that!!LOL
Karl
Posted by MikeV on Saturday, July 17, 2004 7:20 PM
Rick,
I just got back from the LHS with a jar of Floquil Weathered Black.
I am going to go try it out right now thinned with some mineral spirits and see how it looks. Wink [;)]
Posted by Anonymous on Saturday, July 17, 2004 7:32 PM
LOL Karl, and he still bought something else Wink [;)]. Seriously Mike its not so much in how dark or tootsie roll you go, its the washes afterwards that make a tire.
i usually take some flat black and mix just a tibble of flat white.
Posted by rjkplasticmod on Saturday, July 17, 2004 8:37 PM
Mike, hope it works out well for you. I've never thinned Floquil with anything except laquer thinner. Let me know how the thinner & color works out.
Regards, Rick
Posted by MikeV on Saturday, July 17, 2004 9:30 PM
Rick,
It came out good. The color is still slightly gray but is a lot better than the flat black or the Testors Rubber color.
The mineral spirits work great with Floquil as they are an enamel anyhow I believe. I have used mineral spirits before with floquil primer with good results also.
What do you wash and dry brush it with on modern aircraft tires?
Posted by Anonymous on Sunday, July 18, 2004 12:49 PM
drybrush silver Big Smile [:D]
Mike, Try Flat black mixed with a LITTLE white (like in a 5:1 ratio) and about 2 parts of gloss. thats what i use. works great, it's kinda glossy but not too glossy, not flat, and not all black (scale effect)
Posted by Anonymous on Sunday, July 18, 2004 5:58 PM
Hey Mike, Could it be that you are almost ready to show us your F-15?Whistling [:-^]
