panel lines arent being painted
Posted by Anonymous on Saturday, July 31, 2004 2:32 PM
i painted a firebird black and the engrave marks around the door stayed white, its probably because i didnt use a primer, but is there anyway to paint them ?
    April 2004
Posted by crockett on Saturday, July 31, 2004 3:49 PM
I suspect your paint was a little too thinned out. Once your top coat is dry, just reshoot into those lines and you should be okay. You didn't say if you were brushing, airbrushing, or using a rattle can. If you are mixing enamel you should thin about 2 parts paint to one part thinner in the airbrush. Next time, shoot your paint into those nooks and crannies first, let it dry, and check to make sure you've got coverage-do this under very good light and pitch the model into every visible angle when you check it. When your satisfied, then shoot the rest of the car.
Happy Trails....
Steve
Posted by Anonymous on Saturday, July 31, 2004 4:22 PM
i airbrushed with boyds enamel, thinned 50%. 50%. so thats the prob. thanks.
Posted by Anonymous on Saturday, July 31, 2004 5:07 PM
don;'t forget the mist coat. just spray REALLY lightly, let it dry for maybe an hour or two, then spray your normal coats. remember, spray several light coats than 1 heavy coat
Posted by dubix88 on Saturday, July 31, 2004 7:13 PM
HEY,
Ya what he said or you will get runs, and they can ruin the best of models.
Randy
THATS MY VOTE "If a woman has to choose between catching a fly ball and saving infant's life, she will choose to save the infant's life without even considering if there is a man on base." -Dave Barry In the words of the great Larry the Cable Guy, "GIT-R-DONE!!!"
Posted by Anonymous on Saturday, July 31, 2004 8:20 PM
yes, i just re-sprayed it with thicker paint. this is the first time ive used this brand, different than tamiya.
Posted by Anonymous on Sunday, August 1, 2004 8:49 AM
I have to agree with 1337. Except that I will usually do 2-3 mist coats before applying wet coats. While your in the mist coat stage the model will look pretty ugly. The surface will look a tad rough and transparent. After the first wet coat it will all disappear.
If you apply to much paint in the beginning it has nothing to stick too. Therefore it just runs off any sharp edges and panel lines. The mist coats provide a "tooth" for the paint to stick to.
FSM had an excellant article on this very subject a few months ago. December 2003 issue to be exact. "How to get great spray-can finishes by Matthew Usher."
Darren
