Connecting a regulator to a compressor
Posted by Anonymous on Friday, August 6, 2004 6:58 PM
Can I screw a regulator directly onto a compressor, or should I use a cable from the compressor to the regulator?
I'd rather screw it on directly, because I can't find any 1/4" to 1/4" hoses under 15' long - I only need about 2' maximum.
I have the blue mini Testors compressor, Paasche airbrush, a Husky mini pressure regulator (<$12 from Home Depot) and various male/female 1/4" fittings.
Appreciate any replies
Neil
Posted by Anonymous on Friday, August 6, 2004 8:08 PM
i think u can screw it directly to the compressor, mine is and i've had no probs ( which it kinda came with the regulator
Posted by Anonymous on Friday, August 6, 2004 8:19 PM
Thanks - I didn't think it would be a problem!
    July 2003
Posted by saltydog on Friday, August 6, 2004 8:21 PM
as long as you compressor is within arms length of your workbench, it wouldn't be a problem to connect it directly to your compressor. i used to have mine done that way until i bought another compressor that was too annoying to leave inside. she's under the garage and my regulator is mounted to my workbench right at eye level when i'm sitting at the bench. you should be able to find an assortment of adapters and couplings at a local hardware store over in the gas/air connections section. later.
Chris The Origins of Murphy's Law: "In the begginning there was nothing, and it exploded."!!! _________ chris
    January 2004
Posted by MusicCity on Friday, August 6, 2004 8:48 PM
You can do it however you want. The only thing to be concerned about would be if the full pressure output of the compressor exceeded the pressure rating of the hose going between the compressor and regulator if it were mounted remotely. That isn't going to be a problem with an airbrush compressor.
I actually have two regulators on mine because my compressor is about 50' away from my bench. I have one on the compressor, a 50' hose over to my bench, and a "Convenience" regulator at my bench because I got tired of walking over to the compressor to adjust the pressure.
Posted by Anonymous on Saturday, August 7, 2004 1:24 PM
Thanks everyone.
I connected it directly and eventually got it working - I'm looking forward to sparaying at 15 psi instead of 35psi!
Posted by Anonymous on Saturday, August 7, 2004 7:00 PM
My miniblue never got to 35psi Disapprove [V], but then I have a regulator like your setup and love it
Posted by MikeV on Saturday, August 7, 2004 8:42 PM
Neil,
You can connect it directly as I have the same thing on my Million-Air compressor, but the only disadvantage is that the heat of the compressor can get more moisture into the regulator because of it being so close.
