How to do panel line when the body paint is arclyic
Posted by Anonymous on Thursday, September 30, 2004 12:54 PM
Hi guys, I'm building a rally model but have this question in mind.
How do i do the panel line when the body paint is arclyic?
I mean will the body paint get disolve when i try to clean the panel line after washing? I use Tamiya anyway. If yes, what can i do?? oil paint?
thanks.
    December 2003
Posted by danok2 on Thursday, September 30, 2004 3:32 PM
Tim,
Try using a "sludge wash" of artist's watercolor (sold in tubes), water, and a drop or two of dishwashing liquid. You can clean up the panel with a paper towel (slightly) moistened with water. The water will not harm any of the commonly used model paints.
-Dan
"Ahh, the Luftwaffe. The Washington Generals of the History Channel."-Homer Simpson
Posted by Anonymous on Thursday, September 30, 2004 6:06 PM
if you have an airbrush and you haven't painted the fuselage yet, try preshading. use black to roughly go over the panel lines, nothing too fine, maybe 5 minutes for the whole thing. then when you paint, use lighter layers of paint. worked incredably well for me
    January 2004
Posted by MusicCity on Thursday, September 30, 2004 9:42 PM
Once the acrylics have dried you can put a coat of Future or other clear gloss over the paint. Some colors of Tamiya paint (specifically flat black) are terrible about dissolving when anything is brushed on top of them. The gloss coat will protect them from that, and then you should be able to use acrylic or enamel washes.
Acrylic washes using artist's acrylics work well, but the surface needs to be very smooth and you should only let them dry for a minute or so before removing the excess. As Danok2 mentioned, artist's water colors also work very well.
Posted by Anonymous on Friday, October 1, 2004 1:57 AM
Try this link about the sludgewash. It's what I mainly use. I always apply a coat of Future before starting the wash.
http://www.finescale.com/fsm/default.aspx?c=a&id=294
Posted by pingtang on Sunday, October 3, 2004 9:03 AM
I use an enamel wash on acrylic paints. I paint on a line of black enamel (you don't have to thin it). Then , when the paint is touch dry, get a cotton swab moistened with enamel thinner and wipe of the excess paint, leaving a line in the panel line. This works best on a gloss finish, and make sure the acrylic paint has dried completely.
The enamel thinner should not have an effect on the acrylic paint. I've used Humbrol enamels over Tamiya Acrylics alot and have never had a problem with it. Experiment on a small area first.
hope this helps.
-Daniel
