Another Omni 4000 Question
    March 2004
Posted by bstrump on Tuesday, October 5, 2004 10:31 PM
I just got mine yesterday and today I played with it a bit. I noticed however that when I depress the trigger, it's flowing paint even before I've rocked the trigger back. This can't be right. Anybody got an idea of what's going on and how I can fix it? It's spraying about a1/32 to 1/16 pattern just by pressing the trigger down.
Other than this little glitch, it's performing light years ahead of my Badger 200. I can see though that I'll have to break down and get a regulator as well.
Posted by MikeV on Tuesday, October 5, 2004 10:39 PM
Is the needle seated into the tip properly?
Take off the handle, loosen the needle chuck, and push the needle forward until it makes firm contact with the tip and re-tighten the needle chuck.
Don't push too hard on the needle though as you don't want to damage the tip.
    March 2004
Posted by bstrump on Tuesday, October 5, 2004 11:00 PM
Thanks for your reply, Mike. I had a suspicion that's what it might be but I didn't want to start messing with it until I heard from someone more knowledgable than myself. When I get home tonight I'll try your suggestion. Once again, thank you.
Bert
Posted by Anonymous on Thursday, October 7, 2004 11:09 AM
Another thing too. What could be happening is you are shuting the paint off during your practice before shutting the air off, which leaves a small bit of paint on the needle which blows out in a small blob when you start to paint the next stroke. its all trigger practice.
Jeff
    March 2004
Posted by bstrump on Thursday, October 7, 2004 3:43 PM
Thanks for your reply, Jeff. I'll remeber that tip for the future. MikeV was bang on with his suggestion though. When I first looked at it, I would' ve sworn up and down that the needle was completely seated, because when I followed Mike's advice, the needle really didn't move at all. Now that I have this glitch taken care of, I'm absolutely amazed at what I can now do. Swiching from the Badger 200 was almost like stepping into another universe.
Cheers
    January 2004
Posted by MusicCity on Thursday, October 7, 2004 6:23 PM
I do the same thing from time to time when I clean mine. I'd have sworn the needle was seated but next time I use it I start to get paint as soon as I give it air. After the first time you know what causes it, reseat the needle, and keep on going.
Posted by MikeV on Thursday, October 7, 2004 7:27 PM
It is also possible to get a paint clump stuck in there so that it does that while painting. In that case you just pull the needle back, blast some paint through it and push the needle back into the tip.
This usually clears the problem.
